Ahhhhhh This is a fun one! Ok here is the first thing you should do. Put a disk in the tray and keep in mind the position it is facing. Close the tray and wait for your system to say open tray now open the tray and examine the disc. Let me know if it is in the same position and we'll go from there!
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
if the problem still persists then you need to replace your disc drive. Please vote for me.
yeah, you can keep opening and closing it till it works or you can send it in to get it repaired. i tried every way possible to fix it, but i couldnt. something in the dvd drive has gone out and won't read discs the same anymore.
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
it could be that u got **** like food in your x box360 open it up and clean it out put it back to gether and try it if this dose not work tell me at [email protected] ty
HI, the DVD-ROM drive is malfunctioning. this will usually start with a failed optical lens assembly issue but, this is a bit different. The actual spin motor has failed first in this case. due to this damage, you will need to replace the DVD-Rom drive asap. this will fix this issue.
It may just be that your dvd drive's laser is dirty (idk how) but thats what was wrong with mine. It would say that there way no disk or that my 260 games were dvds, then I took it apart and cleaned the laser. That fixed my problem so it might work for your system just google "how to take apart 360" and you should find some guides of taking it apart. Anyway hope this helps!
