My 360 wont read the disc. it keeps saying open tray. i do that and it wont load the game and open tray pops back up. sometimes it will play after a long time of opening and closing thetray
1, the disc may be dirty 2. the mian reason for this your xbox drive
cannot read the disc , because the power of the lens is gone(not
completely) ,
solution:
1. keep your disc inside the drive
and switch off the console, again swith on try this 2 to 3 time 2.
keep the console in vertical position or little slanding position(180
dg) make sure it does not fall
3. its better to buy hatddisc and
load the game inside it , so that u lens life increased
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
if the problem still persists then you need to replace your disc drive. Please vote for me.
1. Make sure you REMOVE any discs from your XBOX' tray. 3. Turn on the console again, either by using the controller or the POWER button (NOT the EJECT button) and WAIT for the initial XBOX setup. ... This fixes the OPEN TRAY error 100 % of the time on my XBOX 360. XBOX 360 cd rom is not reading discs Google Search
it could be that u got **** like food in your x box360 open it up and clean it out put it back to gether and try it if this dose not work tell me at [email protected] ty
common xbox flaw mine does the same ,just keep opening and closeing the tray till it reads the disk,this can be very annoying .your dvd tray is probally on the way out
It sounds like you will need a drvie replacement or motor. Sometimes the magnetic disc on the motor comes loose and it sticks to the top of the dvd drive cover and causes it to not function. We can fix this for you if your interested email us. [email protected]
