The cooling in the ref. section is done w/ a vent that passes air from the freezer. The adjustment maybe labeled "freezer temp". When you locate it, check w/ hand for cool airflow. Insure that it is not blocked. Set vent control @midpoint and give it 24 hrs to stableize.
P.S. If you have a defrost problem, the coil will frostup and not allow proper airflow. Check rear panel for frost build-up, and check if your freezer can keep ice cream hard. If either, leave unit off overnight w/ doors proped open, then re-check operation.
