20 Most Recent
Magic Chef Freezer. 8.8 cu. ft. Upright Freezer in White MCUF88W Questions & Answers
Setting tempture
Turn the temperature control in the direction furthest away from the off setting.
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
I have a Magic Chef freezer built older than 20 years. 15.2 cu. ft. pt. no. 101403-1
Hello Darrell;
My name is Peter. I am a retired field service technician.
Why do you think your Magic Chef is still working after 20 years? Your unit was manufactured with reliable cast steel components.
Do you want to purchase a new unit with more efficiency with components manufactured with plastic and cast ceramic. If you do decide to purchase a more efficient unit, do not discard your well build Magic Chef. When the new unit fails after 5 years, you will always have the older well built unit.
11/14/2014 12:08:51 AM •
Magic Chef...
Answered
on Nov 14, 2014
