Yahoo Messenger Logo
Posted on Dec 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why i cant sign in to my yahoo messenger even my id and password are correct?
Krishnendu Sarkar
Level 3:
  • Master 384 Answers
  • Posted on Dec 30, 2010
Krishnendu Sarkar
Master
Level 3:
Answers
384
Questions
Helped
59938
Points
1364
Check the upper case and lowercase of your password .
1helpful
I enter correct ID and password but cannot sign in to Yahoo messenger I enter correct ID and password but cannot sign in to yahoo messenger
hey
it would be u had forgot ur password
1st select the option forgot passwrod at sign in window
then
yahoo will ask u the security question wat u wrote while creating ur id answer to those question then can rest ur password
Why i cant log in to yahoo messenger?when sign in its say my password or id is not corect but when i try to yahoo mail it right.why?
Try using a different browser like Firefox, Internet Explorer, or Chrome. Are you using a different computer? If so, the website may not recognize any cookies, sometimes this will result in an error code or preventing you from signing in even with the correct id/password. Make sure you are using caps or non caps as your sign in may be case sensitive.
If you are still unable to sign in with a different brower or using the computer you normally use, you may need to change your preferences. Go to messenger and click on "connection preferences", then click on "connect directly to the internet", click "apply", click "Ok" to sign back in.
If all else fails, try uninstalling and reinstalling messenger. Go to Control Panel and click on "Programs" Find messenger and click uninstall. Then go to http://messenger.yahoo.com/ to download and reinstall.
Cant sign in
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "Firewall with no proxies" option.
3. Select the correct Internet connection type and country from the pull-down menus.
4. Click the "OK" button at the bottom of the window.
5. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
6. Enter your Yahoo! ID and password and click the "Sign In" button.
The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps:
1. Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps:
2. Enable the "Use proxies" option.
3. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings.
5. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button.
download registry cleaner reg in out to solve the problem easily
Pls help me i cant sign in on my yahoo messenger and email accout
Check if your password and id are correctly enter. Please check and enter it again. But if it continues follow the steps to recover your password and id.
First of all, you go to yahoo mail.
Click i can't access my account.
Select forgot my password or my account has be compromised
Click Next.
Enter your I.D and code shown below.
Verify your I.D.
Reset your password.
A message will be sent to you via e-mail. So there is when you will get your password back
7helpful
2answers
How to register at yahoo messenger?
When you a have an account with yahoo mail automatically you are sign to yahoo messenger. So you need a yahoo ID before you can enter yahoo messenger and you have you have yahoo id you will log in with your yahoo id and password. to enter yahoo messenger.
You can click on yahoo messenger icon and enter you id and password and then click sign in.
But if don't have the yahoo messenger icon, just go to yahoo and click on yahoo messenger and enter your id and password to sign in.
I cant login on my yahoo messenger hellp me please
It is simple to log in on yahoo messenger. What you is to.
Click on the yahoo messenger icon.
Enter your ID and Password.
Then click Sign in. It will open.
So check your ID and password. If it is correct and try again.
I cannot connect to yahoo messenger, it says, there was a problem signing you in to Yahoo Messenger Please click "try again" to re-enter your ID and password, if you have forgotten your ID or password,...
May be ur entering wrong password or id.....click on forgotten password....if u remeber ur correct mail id enter ur mail id....or u can answer the two questions and enter your date of birth.....if u enter it correctly it will let u change ur password n u can agin login using new password......hope this helps....
2helpful
2answers
Why my yahoo account has been locked?
Too many login tries with wrong password on one ID causes lock the ID. This is a security lock for your Yahoo! ID. If you know the correct password you can unlock it by opening http://www.yahoo.com/r/m6 or http://mail.yahoo.com, for the first time type your ID correctly and type any password(if password is wrong no problem), click Sign In . in reply the same page will appear again... this time type your ID and password correctly, type the captcha verification code correctly as shown in image box and click Sign In. if your password is right your ID will be unlocked.
Thanks for joining Fixya.
Good Luck
Hi i cant sign into yahoo messenger ive tried
u must b using wrong email id and password..check with othr id
Top Yahoo Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
