Question about Yahoo Messenger
I cant sign in to yahoo messenger. my yahoo id and password are both correct. it always appear yahoo messenger troubleshooter. it said that there might be a problem to internet connection but its all fine. when i click the troubleshoot button, i still cant sign in.i am sick and tired doing this over and over again. please help!
Posted by sweet_jacque on
KarooLark
    New Friend:
  • 104 Answers
Use web Yahoo! messenger instead, you might be blocked from access yahoo messenger service.
http://karoolark.com/#yahoo
Posted on Jul 08, 2011
I cannot sign in into yahoo messenger,every time I try to sign in I was read the troubleshooting,what I should do?
try to proceed with secutiry question/answer path.. and also check your log-id and as well password matching.. last but not least there may be a chance of hack..
Oct 12, 2012 | Yahoo Messenger
My yahoo id blocked
If your Yahoo messenger giving you the pop that Your account has been locked, just go to http://www.yahoo.com/r/m6 or http://mail.yahoo.com put your ID and password click Sign In, on reply the login page will appear again now type your ID and password correctly as well as captcha varification code as shown in image box, now click Sign In and you will be successfully logged. Check whether it is helpfull.
May 05, 2011 | Yahoo Messenger
I cant sign into messenger. always aper messenger troubleshooter
Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences."
2. Enable the "No network detection" option and then click the "OK" button at the bottom of the window.
3. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button.
4. Enter your Yahoo! ID and password and click the "Sign In" button.
you may have a registry problem download reginout to fix the issue
Mar 24, 2011 | Yahoo Messenger
Troubleshooting cant sign automatically
Clickthe "Messenger" menu in Yahoo! Messenger and select "ConnectionPreferences." 2.Enable the "No network detection" option and then click the"OK" button at the bottom of the window. 3.Yahoo! Messenger will ask you if you want to sign in again with your new proxysettings. Click the "OK" button. 4.Enter your Yahoo! ID and password and click the "Sign In" button. youmay have a registry problem download registry cleaner reginout to fix the issue b>
Feb 09, 2011 | Yahoo Messenger
I cant login on my yahoo messenger hellp me please
It is simple to log in on yahoo messenger. What you is to.
Click on the yahoo messenger icon.
Enter your ID and Password.
Then click Sign in. It will open.
So check your ID and password. If it is correct and try again.
Aug 01, 2010 | Yahoo Messenger
How do unlock my messenger?
So many log in tries of an Yahoo ID with wrong password causes lock.. This is a security lock for your Yahoo! ID. If you know the correct password you can unlock it by opening http://www.yahoo.com/r/m6 or http://mail.yahoo.com, for the first time type your ID correctly and type any password(if password is wrong no problem), click Sign In . in reply the same page will appear again... this time type your ID and password correctly, type the captcha verification code correctly as shown in image box and click Sign In. if your password is right your ID will be unlocked.
Thanks for being with us.
All the best.
Nov 30, 2009 | Yahoo Messenger
Locked out
Please unlock your ID by following below steps.
All the best.
Why my yahoo account has been locked?
Too many login tries with wrong password on one ID causes lock the ID. This is a security lock for your Yahoo! ID. If you know the correct password you can unlock it by opening http://www.yahoo.com/r/m6 or http://mail.yahoo.com, for the first time type your ID correctly and type any password(if password is wrong no problem), click Sign In . in reply the same page will appear again... this time type your ID and password correctly, type the captcha verification code correctly as shown in image box and click Sign In. if your password is right your ID will be unlocked.
Thanks for joining Fixya.
Good Luck
Nov 18, 2009 | Yahoo Messenger
My instant mesenger when i type in my password says locked
Open the page http://www.yahoo.com/r/m6 put your ID and password click Sign In the login page again will be appearing but there wil be change...put your ID and password correctly here and the put the Captcha correctly as it's showing in image now click Sign In.Your ID will be unloacked now....Good Luck
Oct 15, 2009 | Yahoo Messenger
I cant sign in plss help me if i sing in there
The best attempt to unlock your ID is, try to login not by yahoo messenger, but by mail of yahoo which has a same user name and password that been locked. Sometime, this step worked, but make sure after your login to yahoo mail and success, you have to change your password with new password, and then you can login to yahoo messenger with new password that you just been created.
If you try to send a complain to the contact of yahoo messenger, It will useless. Yahoo doesn’t care what happen to your if you go locked.
To protect your ID or to prevent Lock ID, you must have a strong password. I will suggest you to not chat with your primary email in yahoo messenger. Sometime yahoo makes a prohibition to some of ID. This mean your ID can be banned by yahoo and your ID never be join to yahoo messenger or yahoo email again.
To create a strong password you must use all character who listed in your keyboard. Such as uppercase, number, and symbol. You must be create password which have not less 8 character or more.
Here I give you an example a strong password: H4rP3 ^&* (with 3 space on it). To make a better password work well, you have to change your password frequently: 3 week or 3 month, depending how strong and important your password i
Oct 12, 2009 | Yahoo Messenger
Yahoo Messenger Logo
292 people viewed this question
Top Yahoo Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
