2002 Dodge Ram Maxi Logo
A
Anonymous Posted on Dec 27, 2010
02 dodge ram 1500 heat on passenger side of vechile only
ZJ Limited
Level 3:
  • Dodge Master 17,989 Answers
  • Posted on Dec 27, 2010
ZJ Limited
Dodge Master
Level 3:
Answers
17989
Questions
0
Helped
14459169
Points
60858
If you are getting heat only on the pass. side then I believe the blend door has failed. Dodge has a fix and the job is not easy as almost the whole dash needs to come out in order to get to the heater box and the door. I have read that a simple flush of the heater core will cure it, But that diidn't work for me. I think because dual climate control was an option the door is set up to control the two sides of the cab. When it fails only the pass. side gets heat.
Unfortunatly you do have to remove the dash to access any of the blend door or fresh air door actuators
here is a step by step proceedure this takes aprox 5 hrs in a shop so plan on a weekend at home good luck
FLOOR - DEFROST DOOR ACTUATOR
REMOVAL
WARNING: ON VEHICLES EQUIPPED WITH AIRBAGS, DISABLE THE AIRBAG SYSTEM BEFORE ATTEMPTING ANY STEERING WHEEL, STEERING COLUMN, OR INSTRUMENT PANEL COMPONENT DIAGNOSIS OR SERVICE. DISCONNECT AND ISOLATE THE BATTERY NEGATIVE (GROUND) CABLE, THEN WAIT TWO MINUTES FOR THE AIRBAG SYSTEM CAPACITOR TO DISCHARGE BEFORE PERFORMING FURTHER DIAGNOSIS OR SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE THE AIRBAG SYSTEM. FAILURE TO TAKE THE PROPER PRECAUTIONS COULD RESULT IN AN ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE PERSONAL INJURY.
Disconnect and isolate the battery negative cable.
Remove the instrument panel assembly from the vehicle.
Fig. HVAC housing, dual zone shown (single zone similar)-nut (1), passenger blend door actuator (2), nut (3), inlet baffle (4), recirc door actuator (5), recirc air door (6), driver side blend door actuator (7), HVAC housing (8), bolt (9), defroster door actuator (10), mode door actuator (11)
Remove the electrical connector from the actuator.
Remove the mounting screws from the actuator.
Remove the actuator from the HVAC housing.
INSTALLATION
Install the floor-defrost door actuator to the HVAC assembly.
Install the mounting screws and tighten to 2.2 Nm (20 in. lbs.) .
Install the actuator electrical connector.
Install the instrument panel assembly into the vehicle.
Connect the battery negative cable.
I suggest check (or replace if is necessary), the blend door it is a huge project you have to remove the dash board. There is a repair kit available either way it is a 8 hr shop time project.
Hope helps.
2003 Dodge Ram 1500. No heat on drivers side. Why on passenger side?
Question edited to full make and model.
Blend Door Actuators. They are electronic and run be small servo motors.
https://www.google.com/search?q=2003+dodge+ram+1500+blend+door+actuator+location
I have a 2008 Toyota Corolla and heat on the left side and the right side is cold, what to do?
Heat is blowing on passenger side, but cold air ... - RepairPal
repairpal.com > Questions > Dodge > Ram 1500 > 2002 Dodge Ram 1500
Dec 7, 2009 - When I turn on the heat, the passenger side is receiving warm/hot air but ... blow hot air on the drivers side and it would get cold right away. about a week ago... I have a 2008 Dodge Ram 2500 SLT. ... Regardless of the settings cold air blows from the left vent and on the floor on driver and passenger sides.
Temperature Blend/Recirculation Doors May Fail and ...
repairpal.com > Problems > Jeep > Grand Cherokee
2008 Jeep Grand Cherokee143,000Visitor. I get cold air on driver side and warm air on the passenger side. Upvote (29) ... right side air is always at the coldest. no heat on the right side and air temp will not change, left side works good. .... Models: · Honda Accord; ·; Toyota Camry; ·; Honda Civic; ·; Acura TL; ·; Toyota Corolla ...
Heating and AC Temperature and Air Delivery Mode Do
2answers
Where is the # 2 cylinder located on a dodge ram 1500 4.7 motor
its a V6 so there you must find where 1 cylinder is and on the oppesite side is the number 2 cylinder it works like this 1,3,5 are on one side and 2,4,6 are on the other side
1helpful
I have an 06 dodge ram 1500 quad cab and there is cold air coming in on the passenger side like there is a vent open when the heat is on high and hot on the floor it barley keeps up with the draft and all...
my 02 is doing the same thing haven;t figured it out yet but its either the switch or the flap inside the duct, if you happen to figure it out let me know!
1helpful
2002 DODGE RAM 1500 P/UP , AC TEMP PROBLEM
Have you checked the cowl to see that it is free and clear of leaves and dirt? You may have to take the plastic off to get down into it and sweep it out with a vac. Usually it is right under your wipers.
1helpful
2002 dodge ram 1500 heat only works on passenger side
the vents run off of vacuum could have a leak or the doors in the air duct are stuck (could be leaves or just dirty
4helpful
2answers
Heater only giving heat on one side of truck
I had same problem
it was a blocked drivers side heater core.
Good luck to you
they told you the truth....there is no way to repair it without removing dash
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
