1 Disconnect all accessories and wired controllers from the Xbox 360. 2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
The wired and wireless controllers can be actively connected to an Xbox 360 console all at one time. Each connected controller is assigned a quadrant on the Ring of Light. Before you can connect a wireless controller, at least one quadrant must be free and will be unlit.
Connecting an Xbox 360 Wireless Controller to an Xbox 360 Console is called Connecting. To connect a controller to a console: First, Press and hold down the Guide Button on the wireless controller until it turns on. Second, Press and release the power button to turn the console on. Third, Press and release the connect button on the console. Fourth, Press and release the connect button on the controller. Fifth, After the ring of light on the controller and console spin and flash once, the controller is connected. The quadrant that remains lit indicates the controller's position.
Four Green lights on the controller's Ring of Light flash continuously
The Please Reconnect Controller message appears on the monitor
There is interference and the controller does not respond properly
Step 1: Ensure that either the AA batteries are new or the Xbox 360 Rechargeable Battery Pack has a full charge.
Step 2: Ensure that you have performed the proper procedure to connect the Xbox 360 Wireless Controller to the console.
Step 3: If still experiencing issues, ensure there is a clear line of sight between the front of the console and the wireless controller. If there are any obstructions, especially metal objects, remove them.
Step 4: 2.4 gigahertz cordless telephones, microwave ovens, and Bluetooth headsets for cell phones can interfere with the operation of the wireless controller. Turn off or unplug those devices and then try to connect the wireless controller to the console again.
Step 5: If these steps did not resolve the issue, the wireless controller may need to be replaced.
If the ring of light keeps blinking, it means that the remote controller was not connected to a receiver which is the XBox 360 console. Try to press the connect button on the console and the wireless controller to sync them together.
I had a similar issue with the XBOX 360 Wireless controller. It blinked slow when it was turned on and when synced, the XBOX got the signal, the controller got the signal, but after the full flashes of both, the console ring stayed dark and the controller kept on blinking.
I managed to get it connected by powering the console on using the "XBOX" button on the controller and then pressed the connect button just as the console was opening up the user interface, apparently the console is looking for controllers when it's just getting up and running and syncs better at that point.
I think you only have two options here. 1. Change the batteries or 2. hit the small white button on the top of the controller between the triggers and also hit the small circular button on the xbox to the right of the memory slots.
Joe
Try moving the xbox away from anything metal, most notably your TV, and then turn the xbox off. You may have to do the syncing again, but moving it away solves most people's problems.
