Acer Aspire 9410 Notebook Logo
Posted on Feb 22, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My laptop screen went out on me. When i power it up the status light appears to be booting up normally but the screen is still dark. I've tried to hook it up to an external monitor but still no picture. What can the problem be and should I think about just getting a new laptop? Thanks
General Systems Consulting
Level 3:
Top Expert:
  • Master 5,051 Answers
  • Posted on Mar 09, 2018
Master
Level 3:
Top Expert:
Answers
5051
Questions
0
Helped
1060792
Points
15385
Did you hit the keys that makes you toggle to an external display. Sometimes you just can't connect an external monitor, you have to hit keys that toggle between display on laptop only, display on both laptop and external or display on external only.
5 Related Answers
Anonymous
  • 3614 Answers
  • Posted on Jan 16, 2008
SOURCE: COMPAQ EVO n600c DIsplay back light out
Your liquid display has been probably damaged because of dropping it down, laptop LCD screen is one of the most delicate part of a laptop, it needs a tender loving care from the user when we just only cleaning it surface with a provided cleaning solution for it.
You said that it was dropped its much probably that your laptop LCD screen broke. I had the same experience like you when my sister pulled the strap of my bag were my laptop was there i place on top of my cabinet so that she cannot used it when I'm away. But she sees and because she wanted to play games she pulled the bag down and my laptop bangs on the floor.. And it was broke.
For you u can still bring it to the service center to replace your LCD or for some availabity of stocks you can order it directly from the Main service center probably US.
When i hear that story from you the memories of like what also happen to me came back.. tsk..tsk... So when it happens I learn and give me a lesson that my laptop is much safer when i putting it and do my work with my laptiop on the floor. And hide and keep it under the bed with pillows on guard.
tnx
-micro
Anonymous
  • 458 Answers
  • Posted on Jun 03, 2008
SOURCE: Acer Aspire 9303WSMi - 17" LCD Screen is showing coloured static..
More like the LCD Inverter Board..a loose connection would not cause that, unless you pulled the video cable by openening and closing the lid, but again that too is highly unlikely..
imp_squared
Joe L.
  • 56 Answers
  • Posted on Oct 01, 2008
SOURCE: Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
jeltey
Scott Jelt
  • 44 Answers
  • Posted on Dec 03, 2008
SOURCE: acer laptop has developed a fully dark screen
I am assuming that you have tried switching from external monitor output and local monitor. There should be a hot key on the keyboard to switch it. Also, try looking to make sure the driver for the display is up to date. I f it was update recently try rolling the driver back. If you need help with doing any of this post a comment. Hope this has helped some.
cpenzes
DEKR
  • 1102 Answers
  • Posted on Jan 20, 2009
SOURCE: Laptop black screen during boot, then normal in Operative System
is it affecting your pc
you can change the bootup display time if you want
but I would leave it as is if your system is not affected by it
Screen began flashing then went dark
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
tip
Had "mirror image" boot screen.
I had a Dell XT2 tablet, brand new-when I went to boot it, the POST screen and Windows load screen were half-off the screen and mirror imaged as well. After trying the Dell website, as well as Google and Bing, with no success, I decided to try a trick that sometimes works on Toshiba Portege tablets too. Remove the battery, unplug the power adapter, and hold the power switch for 10 seconds. Replace the battery, plug back in, and it appears to reset the CMOS-both the Toshiba and Dell boot normally.I suspect that this will work for many other models of laptops, but I have no proof-I do know that it will work on Dell D-620/D-630 laptops. I have also used this trick to bring laptops out of what appears to be a 'hung' sleep/standby state.
on Jan 20, 2010 • Computers & Internet
1helpful
Acer travelmate 5320
IBM Thinkpad R51, screen went dark. At the right screen angle, I can see some light from the windows and cursor, but very faint. At that light angle I can maneuver the mouse and click on windows, so all...
The problem
1 The LCD screen is out or
2 The invertor board behind the LCD screen is out or
3 The backlite is out
You have 2 options
1 To use an external monitor for the time or
2 get the laptop fixed by a tech shop
I HAV A TOSHIBA A-135 LAPTOP, THE SCREEN WENT DARK, AND WOULD ONLY LIGHT UP ON BOOT UP ( FOR 2 MINUTES) AND THEN GO DARK. IT WOULD LIGHT UP OUT OF SLEEP MODE FOR THE SAME (2 MINUTES). I HAVE REPLACED THE...
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click,"Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Dell D600 Battery Causes Screen to go Black
Laptop batteries normally just last for a few years, depending on usage. If your battery is almost done, it may report a 'full' status, but just have the capacity to feed your laptop for a few minutes.
You may check this by disconnecting current while your laptop is started up. If low battery capacity is the cause, the same will happen within a few minutes.
Laptops normally go in standby on low battery, to avoid data loss.
1helpful
Sony vaio screen dark then light
your laptop inverter is going bad. need to replace. you can get it on ebay cheap. the inverter is responsible you the lighting up of your screen. thats the solution REMEMBER TO RATE THE SOLUTION
3answers
might be going into a powersave after it boots...try checking the power options
Problem with laptop screen
you reinstall your laptop........your OS
try to contact your laptop manufacturer for safe replacement/repair.
Feb 16, 2008 • GPS
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
