I just brought a Samsung Home DVD theater system model # HT c550. I have a Samsung Flat screen TV with only 1 HDMI port. I have the cable box and a XBOX game connected already.I have been unable to set up the system so that I can get audio from the TV only. Can you help?
Re: I just brought a Samsung Home DVD theater system...
Hello, put your dvd player in hdmi 1 then use a scart lead for your cable box xbox usually connect to the 3 colour plug at the side of the tv if the don't work get back to me and with model number of the tv and i'll down load a owners manual and help you get connected hope it helps
It sounds like you have an issue with the Anynet+ (HDMI-CEC) function. When the home theater system is connected to a compatible TV by an HDMI cable, you can sync the operations when this is enabled on both the TV and the home theater system.
You need to be turn the feature off on one or both devices. If you have another HDMI port on the TV, you could move the HDMI cable to that port. (Most TVs only have one HDMI-CEC enabled port.) Note: this turns off the audio return channel option. If you only have the HDMI cable connected between the TV and the HT-EM53C, you will need to connect another cable. Depending on the TV, this could be an optical audio cable, analog RCA audio cable or headphone (3.5mm) to RCA audio cable.
You have a cabling and/or setup issue and need to check your hardware manuals (or find them online) for instructions.
I have a Samsung HT-C550, a DirecTV satellite box, a Vizio 37" HDTV, a Sony 5-disk DVD player and a Vizio Blu-Ray DVD player, all peacefully co-existing (with the use of a bunch of cables as well as a Logitech Harmony 700 universal remote).
The TV (not the home theater) controls the use of the TV speakers.
There are multiple options to get this to work. I run an HDMI cable from the sat box to the TV. (HDMI sends audio & video to the TV). I then run an optical cable from the TV to the CT550 and use the "D-In" setting to get the sound to play.
Instead of the optical cable from TV to CT550, you can run audio from the sat/cable box directly to the CT550 using (red/white) RCA cables from the "audio out" jacks on the sat/cable box to the "AUX1" or "AUX2" inputs on the CT550"
You're correct and that is exactly how I always recommend setup (contrary to what the manuals tell you). It makes no sense to me to run any signal through any electronics or interconnections that neither use it nor improve it. Hence, I have NO SOURCE VIDEO going to or through my receiver and NO high end audio going to my TV (which could just as well be a monitor with NO audio capabilities, right)?
Audio electronics should receive the BEST digital audio directly from it's root source.
The TV should receive the BEST video directly from ITS root source.
THAT is why most all high end A/V gear has separate audio and video in/outputs.
If that means you have to make some switching choices when using different sources, oh well. At least you won't have experience potential degradation from multiple hops or have to troubleshoot problems that could be anywhere in that chain.
Try to ensure that you have selected "source" correctly from your TV and that the cables from your HT are set up correctly. If you pop in a DVD to the HT then **** about with the "source" options on the TV you should at least get sound (only one cable to worry about) or everything if you use an HDMI cable. The satellite or cable selection should go via the HT so again make sure if is is hooked up correctly - if you do not see DVD, Cable or the HT "home" screen then your TV may be faulty.
Purchase a 3.5 mm jack (it will have a smaller connnector going into the TV and Red and White connectors on the other end).
Pull all the other cables running into the Blu Ray player out so that you are only left with the HDMI Cable coming from HDMI Out (DVD) to HDMI/DVI In (TV), along with the 3.5 jack.
You will be able to play the TV sound through the system.
the easiest way to get signal to your HT-Z320 is to run the audio cables from your cable or sat box to the input on your theater system...for the dvd either run HDMI to the LED TV or component (whatever it supports) the Wii system can be plugged into any AV -IN on the LED tv (if you want to use the Wii on the theater system you will need to extend your RED AND WHITE audio signal cables to the input on your theater system.
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
