SOURCE: Image blurry at edges
my dear friend, it appears that you must have opened the 3 lcd screws that are not supposed to be touched, if so then just forget reassembling the same as the convergence would be lost & cannot be manually done
another thing are the polarisers.if excessive dust had accumulated & if you used wrong technique in cleaning then the coating would have come off & you have lost everything , just change the entire lcd block.this costs a bomb.beter to buy a new projector
SOURCE: Wide vertical bands of color through the viewing area. The sound is fine
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
SOURCE: black vertical band on left side
There is a good chance that the plasma panle may have become faulty, but another cause of this is a faulty X-SUS Printed Circuit Board or a Y-SUS Pinted Circuit Board, they are labelled which is which on the Circuit Board themselves. Replacing both of these may solve the problem. Good Luck.
SOURCE: Can I clean the LCD Panels on a Panasonic
I the green banding is well defined with sharp edges then it's most likely an electronics problem.
If it's a blurry banding then it may be degradation of the filters. Cleaning the LCD panels is relatively easy when the top cover is taken off, and the main processor board removed. However great care is needed to ensure no connectors or cables are broken, and are replaced properly during reassembly.
