If you remove the seat and the battery cover, you can connect the battery charger positive lead directly to the positive battery terminal. Or, you can connect it to the battery connection at the starter, whichever is easiest to get to. Connect the negatve charger clamp to either the negative battery post or any good ground on the engine or frame of the bike. Once connected, turn the charger on with a 2-amp per hour charge rate.
Good Luck
Steve
