GE DPSR610EGWT Electric Dryer Logo
Posted on Dec 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When the dryer drum rotates it squeaks. It sounds like it needs some sort of lubrication; however, I do not want oil on our laundry.
Anonymous
Level 2:
  • Expert 90 Answers
  • Posted on Dec 17, 2010
Anonymous
Expert
Level 2:
Answers
90
Questions
0
Helped
16319
Points
272
You need new felts they go in front of the drum once you remove the raise the top and take the front off they will be right there on the front panel assembly. they are little plastic pieces that the drum ride on if not plastic it will be along wool type cloth right there in the front in the same place.
3answers
Constant loud squeaking
Squeaking is normally caused by a bad bearing or a slipping drum belt.
Feb 28, 2015 • Dryers
My dryer squeaks
First you should try to determine what the squeak is related to, does it happen every time the drum rotates or more frequently. This will give you some idea of where to look. You should disconnect it , take off the top and get someone to rotate the drum by hand while you listen. Moving parts are dangerous don't put fingers in. Commonly the outer drum bearing or belt idler need lubrication. Don't lubricate the belt. More details if you provide more clues.
4helpful
Squeaking frigidaire stacking dryer
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
1helpful
We've got a Maytag MDE6000AYQ dryer that we love. It started squeaking two loads ago. It would squeak off and on during the cycle. This next load seemed to squeak worse, so I'm worried to use it any...
The squeak is most likely from the drum support rollers or the drum bearing. If it's the rollers, they're fairly easy to replace and often a drop of lubricant will solve the problem. This is just one supplier of such parts:
http://www.apwapplianceparts.com/Laundry+Appliance+Parts/Dryer+Appliance+Parts+/Dryer+Drum+Bearings+and+Felt+Drum+Seals/default.aspx
1helpful
My GE Profile Dryer is still operating but produces loud intermitent noise as the drum rotates. What can I do to eliminate the noise?
It sounds like you may have a bad bearing in the back of the drum. That model rotates on a sort of ball and socket type mechanism. You may be able to lubricate it if the noise is just squealing/squeaking. If it is more than that, you'll probably need to replace the bearing mechanism. If you lube it, use a heavy weight lube that is rated for high heat (I've used brake caliper grease.)
1helpful
2answers
My dryer makes a scraping noise when the bowl
You may have two problems:
1...The felt seal around the door is faulty,broken, or out of place.This will cause the problem of zippers,buttons, etc. to get caught between the door and the drum
2...Drum rollers, this causes squeaks,and thump type of noises.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication and the felt seal between the door and drum maybe faulty.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt,and felt seal.
Check your felt seal at this time to see if you can reinstall it or you may have to replace it.
Remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise and the problem of getting clothes caught in between the door and drum.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
4helpful
Thumping sound from loose drum
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Dryer has a loud squeaking noise when you first start it up
Sounds like your drum rollers need lubrication or replacement.
If you have a front load machine, remove the front of the machine, this will expose the drum. Remove the drum and this will expose the drum rollers. Lubricate the drum rollers with a good grade of machine oil like 3 in One oil at the shaft.
Hope this helps
1helpful
Squeaking
The squeaking is usually attributed to any (or all) of the following:
The drum support rollers
The rear drum seal
The front drum ring bearing
The front drum seal and bearing assembly
The Idler Pulley
Now before you throw yours hands in the air in a panic, these parts sound more technical than they are. All the bearings and seals for the drum are either felt or plastic, the drum rollers support the drum at the rear bulkhead, and the idler pulley is what the drive belt rides on. Searspartsdirect.com offers excellent illustrations to show you where these parts are located. Just type in your complete model number and there will be a part listing with part numbers on the next page. If the model number you posted this under is correct the parts can be found under the following headings:
"Bulkhead Parts"
Drum Support Rollers (item 44) Part #349241T (pkg. of two)
Rear Drum Seal (item 66) Part #279857
Front Drum Ring Bearing (item 62) Part #279441
"Cabinet Parts"
Drum Seal and Bearing Assy. (item 38) Part #3406129
Idler Pulley (item 53) Part #691366
I list all these parts as a convenience in case you need to order any of them, and to help illustrate where these parts are located. You may not need ANY of them.
The drum support rollers require lubrication at the point where the roller meets the shaft with a light turbine oil. This should be done periodically to keep them rolling smooth. DO NOT get any oil on the rubber rollers or it may cause the drum to slip. You should also remove any build of lint before lubricating.
The drum seals can become brittle with age and start making noise as the drum rotates. This is particularly true with the rear drum seal. It will become discolored with age and turn brown in many cases. Inspect the front and rear seals of the drum for excessive wear. If parts of the seal begin to protrude into the interior part of the drum, this is a good sign that the seal is bad. The seals cannot be lubricated and will require replacement.
The idler pulley is a small plastic wheel on a shaft that the drive belt rides on. Lubricating the idler pulley wheel in the same manner as the drum roller supports is also required from time to time. DO NOT get any oil on the drive belt.
I know this seems like a lot, but a simple matter of cleaning and lubricating may be all that you need. If you require further assistance, please let me know. I hope this helps you.
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
