Computers & Internet Logo
Posted on Dec 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The WPS button is a soild red and wont let any device join wi-fi.
Anonymous
Level 2:
Novelist:
  • Expert 142 Answers
  • Posted on Dec 13, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
142
Questions
Helped
55119
Points
332
First you need to connect an Ethernet Cable between Router and Computer
Open a Web Brower and Type:- 192.168.2.1 You will get a Router Setup Page(if you are not getting Router setup page then you can try this step Click on Start>All Programs>Accessories>RUN RUN window you can type http://192.168.2.1:80) You will get a Router Setup Page
Towards the left side you can find an option> WiFi Protected Setup(Click on it) ********By default no password so leave the box blank and click on Submit
On the First line Disable the Wifi Protected Setup and click on apply changes
Now try connect through wireless
Hope that will fix that issue
Does my zte z835 have a wps button for wifi
Phones do not usually have a WPS button; they often have an option to use the WPS button during Wi-Fi setup. Your wireless router may have the WPS button; check the manual or look at the router for the button location. To connect the phone to a router with a WPS button, go to Settings (from All Apps) and choose Wi-Fi. Make sure that the slider is set to On. Then tap on the icon with three dots in a black rectangle. Choose the Advanced option. Tap the WPS Push Button option and then push the WPS button on the router.
I looked at the AT&T manual for the ZTE Z835 (Maven 3) for the specifics on this section of the Wi-Fi setup. See page 44 (page 46 of the PDF) of the manual: https://images.comparecellular.com/phones/2673/ZTE-Maven-3-user-guide-ATT-english.pdf .
I hope this helps.
1helpful
2answers
I am trying to connect my canon pixma 452 printer to my samsung tablet. Where is the WPS button ?
WPS Connection Method Before we start, there are some conditions that must be met in order to use the WPS push button method:
  • The access point must have a physical WPS push button available. Please check with your device's user guide for details. If the WPS push button is not available please use the instructions on the Standard Connection Method tab.
  • Your network must be using the WPA (Wi-Fi Protected Access) or WPA2 security protocol. Most WPS enabled access points use this protocol.
Step 1 1. Press the [Setup] button (A) on the printer.
Step 2
1. Select [Wireless LAN setup] and press the [OK] button.
The blue Wi-Fi lamp (A), will light up when the wireless connection is enabled.
The printer will now automatically search for access points supporting the WPS feature
Step 3
The display on printer should be as shown below:
(The message will read: "Press WPS button about 5 sec. and press [OK] on the device)"
1. Press and hold the [WPS] button on the access point.
For exact instructions on starting WPS on your access point, please refer to its user guide.
2. Press the [OK] button on the printer within 2 minutes.
The blue Wi-Fi lamp on the printer flashes while searching for or connecting to the access point.
Once connected, the following screen will appear. Press the [OK] button.
If another screen appears, please refer to "troubleshooting" in the user guide.
This concludes the WPS setup procedure.
Please now proceed by installing the software to make the most out of your PIXMA MX474.
  1. If you do not have the installation CD that came with your product, please download the manuals and software.
If the WPS wireless setup is still failing after following this guide, please Contact us for further assistance. 1 888 224 4280
3answers
Can you fix my pixma canon mg3500 printer?
Hi, you need to count the blinks to know what error is.
What is WPS button?
The WPS is abbreviation for Wi-Fi Protected Setup. This function should you help to set up strong wireless network password (so called "shared secret") by very easy way.
For most of users is very hard to create, remember and assign complex long password to Wi-Fi router and client devices e.g. smart phones, laptops, printers.
Short and simple (non-complex) password is weak and can be broken by hackers. You can set strong password using WPS buttons. No device management access is required.
Procedure description
Press WPS button on both devices you wish connect each other. (Router, wireless printer...)Wait until password is set automatically and devices are connected.There exists second procedure in WPS standard. It is similar to described one, but PIN number is required in addition.
Security warning!!!
Enabled WPS function is very high security risk. The WPS sets strong password, but offers another security hole to hackers. The WPS standard is affected by well known vulnerability and therefore is insecure. It is recommended to DISABLE WPS ON ALL DEVICES. Go to device setup and disable the WPS completely.
3answers
What is wps pin
Wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices.
WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either a button on the product or a an option on the wizard or utility screen.
NETGEAR WNR2000 reboot every time to join wireless devices
Are you saying if you hook up bring in the new Wi-Fi device you need to reboot for it to be recognized? Are using WPS?
Wps light blinking
CALL YOUR ISP FIRST.
wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections. Some of NETGEAR's products use the name Push 'n' Connect for WPS. To use WPS, your product must support WPS and be compatible with WPA security. WPS can automatically set up a random network name (SSID) and strong WPA wireless security for wireless routers, access points, computers, adapters, Wi-Fi phones, and other electronic devices. WPS lets you use a push button or enter a personal identification number (PIN) instead of manually entering a network name (SSID) and password:
  • Push button. The WPS button is either on the product or a clickable button on a wizard or utility screen.
Wifi will not connect
The below info is from user manual ... downloadable version @ www.pantech.com
Connectivity
This chapter introduces useful tips on how to connect to the
network available that enables applications of the phone to
run.
Using a Wi-Fi network
Connecting to a Wi-Fi network
1. Tap Settings from the applications menu.
2. Tap Wireless & networks > Wi-Fi settings.
3. Tap Wi-Fi to activate the technology.
4. Select and tap a network. You should enter the password
if the network is secured. indicates a secured Wi-Fi
network.
5. Tap Connect. Once the network is remembered, the phone
will automatically connect to it when in range.
Activating Wi-FI Connecting to a Wi-Fi
network
Note The icon next to each network indicates the strength of the
signal. For example, indicates the signal is poor while indicates
the signal is strong.
Using the Easy Setting
1. Tap on the top of the home screen and drag it down, or
press n in idle mode and tap Notifications.
2. Tap in Easy Setting. The icon turns red when the
function is on.
About network notifications
You are informed by default when a Wi-Fi network is available
around you. The message in the status bar indicates a
network is available. Tap Network notification in the Wi-Fi
settings if you do not want to be informed the availability of the
network.
Setting Wi-Fi networks
4. Tap Network notification if you want to know an open
network available.
5. Tap Automatic connection if you want the phone to
connect to Wi-Fi network automatically.
6. Tap WPS button connection if you want to establish a
new wireless connection using the Wi-Fi Protected Setup
(WPS). You should press WPS button on your Wi-Fi access
point within two minutes.
Searching for Wi-Fi networks
3helpful
Hp printer says to press the WPS button on the router. What's that?
  • Wi-Fi Protected Setup (WPS) is a standard for easy and secure wireless network set up and connections.
  • WPS lets you use push buttons or PINS instead of entering a network name (SSID) and wireless security by hand.
  • Push button: The WPS button is either on the product or a clickable button on a wizard or utility screen.
  • Personal Identification Number (PIN): The PIN is either on a product label or can be viewed on a wizard or utility screen. The PIN is entered for either the router or access point, or for the wireless device that wants to join the network.
Grand Canyon Tech
Grand Canyon Tech
