Hello josh jess031: My name is Roger and I will help you. To locate the blower motor you will need to remove the glove box. After you remove the glove box you will see the blower motor cover. Remove the 4 screws holding the cover. Unplug the wire harness and back the harness out of th heater case.Remove the 3 screws holding the motor and remove the motor. Should the new motor not have the blower cage on it remove the one from the old motor. Reverse the procedure to reinstall the blower unit. Should You need further help please just ask. Please rate the answer you received. Thank You for using Fix Ya. Roger
