Televison & Video Logo
Posted on Nov 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does the model kv-27v10 need a analog converter to recieve local staions or is it already digital
Anonymous
Level 3:
President:
  • Sony Master 1,779 Answers
  • Posted on Nov 28, 2010
Anonymous
Sony Master
Level 3:
President:
Answers
1779
Questions
Helped
579055
Points
5452
If your on cable you wont need a box. If your on outside antenna or rabbit ears then you will need the converter box.
Sony KV-27V10 Lound Buzzin When Screen Full Or Bright
Check for any faulty electrolytic capacitors in the main power supply regulator section.
Can not tune tv since change over
The KV-32FS100 only has an analog tuner (NTSC). Unless there is a low-power analog station still broadcasting in your area, you will not be able to watch OTA stations. (I've got one in my area that barely comes in.) If your local cable still sends an analog signal, you won't need a set top box to watch that subscribed service.
Otherwise, you need a set top box to watch TV. A digital to analog converter (the boxes that were available with the government coupon before the switch over) will give you over the air stations. The basic models only provide SD output; there are a few HD models available. Otherwise, you can use a satellite reciever, cable box (for digital cable service), or something like the Boxee or Sling with tuner. (There are a few different models of the Boxee; one added a tuner with a USB dongle. The newest model of the Boxee has the ATSC tuner built in.)
Note: OTA digital signal quality is either a strong enough signal for the tuner or no signal will be present. You need to point the antenna in the correct direction to receive the signal from your local transmitters. The type of antenna and its placement will also change the number of watchable channels. You can use antennaweb.org or tvfool.com to get more information. Antennaweb assumes an outdoor antenna but gives a conservative list of stations. If the signal is split to several devices, you may need an amplifier to get a watchable signal. (Sometimes amplifiers fail and you won't receive any stations, so test without the splitter or amplifier by using a direct cable to one TV.)
I hope this helps.
Will our Sony Television Model No KD-28-~DX 40U work after the [email protected]
No,as a tv alone only for recieving a free AIR DTV signal broadcasting signal tv channels.This tv is an analoge tv.U must hookup to any analoge tvs to a box that called a Digital Converter box to used to recieving free AIR DTV broadcasting signal for channels.U still can used it for any analoge tvs if u have a pay tv signal broadcasting channels services.
1helpful
Do I need a digital converter box to recieve a digital broadcast with a Sharp LC-20SH4U TV?
Yes you need a digital converter box. Your model has an NTSC Analog Tuner. It doesn't have a Digital Tuner. This is why you need the converter box.
For example, many companies like Comcast or Time Warner or TCI etc used to broadcast Analog Signals through their wires. Now they have broadcasted only Digital Signals. This makes either your TV Obsolete as a Tuner or you have to get a digital converter so your Analog TV can receive the signal.
Depending on your service, it may be worth your while to get a TV with a digital Tuner.
Then again, it also depends on if you are connecting a box receiver to your TV. For example, if you have Directv or Dish, you would then use your standard Video/Audio or Composite Cables to transmit your signal OR your Out to TV Coaxial whichever works for your receiver. Some receivers have already built in converters . You should really consider all the factors to decide and determine it based on the type of service you have or want.
Do i need a converter to watch model kv-9pt40 tv
Can't find the specs but i presume it's an analog NTSC set. You will need a converter to convert the new off air ATSC digital format and if you're on cable, unless they are still converting to analog, you'll need a converter there too. Some cable systems (Comcast being one) will require their own cable box to index the digital channels and convert to analog ch 3 or 4 for your TV.
No channels recieved
If you have cable already, you do not need to use a converter for your picture. You would still just hook your coax cable to the tv right from the cable inlet. The converter is for over the air signals only, so you would place it between your bunny ears and the tv to convert your signal for your tv.
I don't know if my sony trinitron kv-2742 27" tv needs a box
Given the history of the aquirement, I checked the model number and there is no reference to be able to receive digital. You can buy a convertor box anytime they are available to use on the set. There is no deadline to hook it up.
Is my tv digital?
It is not a matter if your TV is compatible with a digital signal, it is the signal being offered to the TV.
Meaning, if you are using Cable TV, you are fine and need no further action because the digital signals are already converted by the Cable Box into either an analog TV (RF) signal, or a PBR (RGB or Comp.Video) signal which the TV understands via a separate input (external video input).
DTV converter boxes
You need to look on the tv and see if has a digital turner symbol. If you can only pick up analog channels, you need a converter box.
Is the Sony FD Trinitron WEGA KV-36FV27 36" TV a digital TV
This is an Analog TV - you will require converter box.
go here to order it: https://www.dtv2009.gov/ApplyCoupon.aspx
jl
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
