I have a acer 3680-2682 having a keyboard problem #3,qesihyvv do not work.went to keyboard prop.it tell me device working properly.just got laptop from mother she never used it.PLEASE HELP!!!!!
Try reinstalling/updating the driver, click: start>control panel>hardware and sound>device manager. Look for keyboards and expand the menu. Right click on the keyboard adapter and click properties. The first tab (general) will tell you if the device is working properly. Click on the drivers tab, choose update driver and search automatically for updated software. You can also try to; uninstall the keyboard, reboot the machine and let windows install a new driver.
Sometimes the keyboard connector to the motherboard becomes loose it may workproperly sometimes sometimes it may not, its better take your notebook to some technical person open the notebook there and attached the connector firmly
if your laptop is outside warranty you can check the connection to the keyboard, by removing the top bezel, undoing the keyboard retaining screws and then check that the ribbon cable for your keyboard is seated properly, If reseating this cable does not work the you can always order a replacement for your keyboard, you can find the part number for the keyboard you have, it should be printed on a tag on the reverse of the keyboard.
You might have a usb keyboard requiring a usb 2.0 driver. If no other usb device has worked with xp since you replaced your hard drive, that could be the point of failure.
Make sure you have installed windows xp service pack 2 to get the usb 2.0 driver.
the 'Add New Hardware Wizard' and force it to install the non-certified M-Audio drivers that were supposedly installed when running the M-Audio installer. (Skip internet search, and browse to M-Audio folder in Program files, it will eventually find them.) There are two M-Audio USB drivers that need to be 'forced' via New Hardware Wizard. But Windows thinks its drivers are a better match and even though 'device is working properly' it doesn't get recognized in your software. replaced them with the 2 USB ones from M-Audio, DAW finally recognized the keyboard. I even went through regedit to clean up all the M-Audio stuff so I could get a fresh install.
Good Luck you can do this /Have a great Sunday and a safe one.
