Acer Aspire 5100 Notebook Logo
Posted on Aug 04, 2009
Unresponsive keyboard + mouse pad
I have an Acer 5100, which is facing
intermittent problems with the
keyboard+mouse pad (unresponsive), however,
when the keyboad works, OS is unable to
load properly. It started with a blank
(black) screen problem. On multiple
reboots, suddenly I could see the screen
display coming up but the keyboard+mouse
pad is not responding.
Laptop is 3 years old, I got it from
Germany.
Please advise as necessary.
Thanks!
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Aug 07, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
9773
Points
23
It sounds like your keyboard/mouse controller chip, or input/output chip. A new motherboard should fix it, or a less expensive route may be a pcmcia usb adapter. The adapter should let you connect a usb keyboard and mouse.
This problem is quite common with Acer.
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Aug 04, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
3852
Points
27
I guess you have a mechanical problem, sounds like the mother board have some issues on starting all devices.
If you could use keyboard to go in the bios, and see the screen, if would be the OS that need to be repaired.
Keyboard and track pad are not working, completely unresponsive.
Try and external keyboard and mouse. If they work then re-install keyboard and mouse drivers by removing then first and let the OS do it.
If this doesn't work your pc might be infected. Try to clean it or save data and re-install OS, that is if the external keyboard and mouse work. If not then it is a hardware problem.
Gateway Pointer Unresponsive
To troubleshoot this problem, first you must get a USB mouse and connect it to the laptop. Now, there are various laptop that have the ability to deactivate the pad control, it's different for every laptop, so you should check on the keyboard if you see anything that resemble the mouse pad. If it does, press it. There also could be a driver problem, just in case re-download the drivers by going to the Gateway website and click on the support tab. Just follow the instructions on the website. You should have an icon at the bottom right of your screen, where the date, battery, etc... are. Right click the mouse pad icon (if any) and check your options. If you need more help I'll be more than glad to help you out, but I'll be needing more info as to the laptop. Best of luck.
Laptop screen frozen;arrow wont move;cant type in user name.ACER Aspire
The appeal to any laptop is the ease of portability of the machine, and an Acer laptop is no different. With an integrated mouse pad, these computers can be quite the boon to those looking to have their technology on the go, but a number of issues can afflict Acer laptops, including unresponsive mouse pads. Fortunately, a few clicks of the keyboard and some driver downloads can alleviate most Acer mouse pad problems.
Take a close look at the Acer laptop mouse buttons. Make sure the exterior of the buttons are clean and that there is no grime around the edges and crevasses of the Acer buttons. Dirt on top of the mouse pad can result in slower performance or an unresponsive experience, while grime around the sides of the mouse buttons can cause problems with the pressing and depressing of the mouse. Is there any way your mouse pad has been turned off? Check into this possibility. On an Acer laptop, hitting the "Function" (Fn) key and "F7" on the key board will result in the mouse pad being switched off. Hence, you may have hit this function and your mouse pad may not actually be broken or require any repair. Hitting the "Fn" button and the "F8" key on the Acer keyboard will result in the mouse pad being turned back on again. Click on the "Printers and Other Hardware" option on your PC. This is an alternative method to the above. At this point, examine the menu that comes up and click on the button at the top that reads "Device Settings." You should then see an option to click on your Acer mousepad. Highlight this option and click "OK." Launch your Web browser and go to the official Acer website. http://www.acerpanam.com/ The above steps may not have worked, so downloading new drivers for your mouse may be necessary. Select your country of origin, then click on "Support." You will be asked to click on your country again. After you do so, click on the link that says "Drivers and Downloads" on the left sidebar. Select your product line ("Notebooks") as well as your specific Acer computer model, and then hit "Search." Click on the link that says "Touchpad drivers." Your Acer computer may only require new drivers for your mousepad. Download the .exe file and run it to install the contents to your Acer computer. Restart your Acer computer after fully completing the download and installation process. Once the restart process has completed, the driver installation will be complete and your mouse should work again.
b>
Acer aspire 5100-3583 boots, screen is on, but
https://www.bleepingcomputer.com/download/windows-repair-all-in-one/
Keyboard and mouse pad on my laptop. Acer 5100 vista
On an Acer, the Fn key plus F7 will turn the touchpad on and off.
Try that to see if it works.
Keyboard and mouse stopped working
I would check the Flex cable's first. If keyboard is not working sometimes this does not allow the pad to work. Here is one of the sites I use for repairs. Good luck and have a good day.
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
Keyboard not working
usb is tyed in to the mouse and active key both below the mouse pad got same problem
2answers
Acer 3500 mouse touchpad totally frozen
have you tried updating the driver
or go to control panel and mouse and check the settings in there
does your laptop work with a normal mouse
2answers
Keyboard and Mouse completely unresponsive
Hmm have you tried an external usb keyboard ? if it works all you need to do is restore your computer to a previous date , one in which they were working :)
If not you will need to take your computer in to a profession for them to reset and flash your board, and if that doesnt work you will require replacement parts..
BTW plugging the mp3 player into the usb should not have cause that issue :)
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
