I'm trying to install a radio in a 1974 Ford LTD, the old wires have been cut so didn't try to figure that mess out, so instead as the manual said I ran a wire off the battery and one from the radio fuse for power then grounded the radio. This has the lights coming on and the CD player working but there is no sound to the speakers. New speakers are being used and new speaker wire was run. Have taken the radio out and tried it in another vehicle and the speakers work, have also tried another radio in this car and came up with the same thing, no sound. What have I done wrong or need to change to get sound in my car?
SOURCE: Blown Fuse are Wiring Problem
Dear riggsmarry
i m sure u r battery & fuse is ok.....now u have to do is to check u r all power cable connection,,,,,,,,,due to shot circuit they might damage...........
just check u r all power cable connection carefully.......
Regards & best of luck
for more information on this topic u can mail me too
[email protected]
sir
if u r problemis solved then let me know by VOTING me.....
-Was this solution helpful? Show your Appreciation by rating it:AS FIXYA
SOURCE: KEH P4750 wiring diagram
I hope this picture is worth thousand words for you
Picture tells about the power input and the sound input.
SOURCE: radio works, but no sound
you cannot get a wiring diagraam for fuse box as its sort of secret as the immobiliser workings are incorporated in it
SOURCE: cd player plays, but no sound comes out of speakers.
Look at the enwood. I bet you have the remote wire hooked to the blue wire insted of the blue/white wire. The blue wire goes dad when you play a cd as it is for a power antenna. The blue/white wire is your amp turn on.
Now, if you do not have a blue/whie and only blue, then obviously that circuit in the radio is bad in whch case your only other option s are either connecting it to an accesory fuse or using a toggle switch connected to power.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
SOURCE: my ford ka cd player only plays out of one speaker
When I first got my Ka, the wiring between the car and the door was snapped. If you open the door there is a rubber tubing, if u assume 2 wires are snapped and try 2 pull them together through the rubber tubing you should hear a crackle if thats the fault. Even if you do not, it will almost certainly be this. To fix it, you need 2 use a stanley knife 2 cut open the rubber tubing then connect the to snapped wires together. I did this by getting a small amount of speaker cable and adding it 2 both ends, using plenty of insulation tape. This is the most common fault for speaker problems in the Ka.
Hope this Helps
Ashley
