SOURCE: transmission slips in and out of third gear
sounds like you need to have the fluid changed and a new filter put in.. good-luck ray
sounds like a shift solenoid in the trans.
SOURCE: Transmission does not engage into reverse sometimes.
Sounds like filter and fluid change would be in order. If it does finally go into reverse that would be my best guess. Hope this helps and have a great day.
SOURCE: would you say suzuki forenza 06 is a good car to buy?
They have been doing well and there problems are fewer than most. Sounds like you have a pretty good car. Have those trouble codes checked and repaired though so it does'nt cause problems down the road. Good luck.
SOURCE: tranny struggles to shift to 2nd gear on fast take
you should have this scanned at a at good transmission shop . its can be tough situation to solve these issues when concerning trasmission issues. even tougher when you cant afford mechanical issues even worse transmission issues like differentals ,shift solenoids ,pressure solenoids ,etc. i just noticed rereading your situation you dont mention any trouble with 3rd or 4th gear i assume no problems 3or4th gear and take off in 1 st i assume is no issue either. just to let you know w/transmissions there can be simular issues with different solutions, couple of things first check for a air modulator valve, driver side between transmission and radiator it will have vacuum line on it going to your intake make sure all the way connected or need replaced. also right below your modultor is a transmission mount have someone help you for this. have someone put the car in drive hold brake firm and give it gas see if the trans mount is sloppy or broke if it is fast acceleration would cause your shifting problem 4 sure esp going to 2nd gear. tras mount $65 modulator $50 . 1 nut holds air mod. on easy do it your self fix. dont forget o ring if replace the air mod. . cheaper then $1800 to $2200 good luck hope this helps you..
Get it already. Have you prayed?
