Hi, please enter any number say for example, 22
then on the other device when it asks for the pairing code enter the same number ie. 22.
hope this will solve ur problem
Hello, motorola phone pc suite or phone tools software no longer works for using net from mobile. It may better to use bluetooth dongle to connect net. Just purchase a bluetooth dongle then install driver n on your phone's bluetooth and connect it with dongle select PAN connection if possible otherwise make dial up connection. This will surely work Hope this will solve your problem...
try to holding * and # and swith the phone on.
If invitation fot flashing is seen. Take it to service centre.
Motorola phone are unlocked through reflashing
Check your bluetooth connection with the PC and use Moto Tools suite to transfer photos . Other option is to simply make a connection with your PC and send photos one by one or mark all , send all to PC via bluetooth connection
First of all download all the stuff for motorola v3i mobile from internet. key words are p2k commander, moto p2k drivers, rsd lite, motorola midlet manager, moto skin man....etc.
now just connect v3i to pc with cable in data/fax mode....
now install the downloaded p2k drivers.
next install rsd lite.
dats all simply connect the phone and install any java software(.jar and .jad) using motorola midlet manager.
please ensure blutooth is on in the moto and the blackberry and its set in a "discoverable" mode..after that search for bluetooth devices in range and connect..if it asks for a PIN the usual code is four zeroes 0000
hope it helps!
regards!
hi..i guess ull have to bye them...and when u do..u cud use a usb cable to connect to ur pc...and when u do u can access ur motorola phone tools..all the best
Try 0000 this is standard manufacturingdefault code for nearly any blue-tooth device that has security feature enabled and because the moto s9 as far as i can see has no way of being able to change this code it must be still at the manufactured setting
Bluetooth doesn't shut off on its own unless you turn off your phone. In the bluetooth options, you should be able to select "Turning Bluetooth On", "Turning Bluetooth Off", or "Using Discovery Mode (60 seconds)." Discovery Mode, which I believe is what your using, is only used when connecting to another device.
My question for you is, what kind of device are you trying to connect to?
downloading pictures to my pc
