TP-Linkhttps://www.tp-link.com > support > faq
Feb 27, 2023 - Wireless connection could have been lost. Try reboot the device and re-discover on Alexa. · Internet access on your router could be unavailable.
https://www.tp-link.com > cac > support > faq
Try to reboot the smart device and re-discover on Alexa. · Double check whether Kasa App can remotely control the device or not. If not, check your internet ...
Sump temp sensor is not reading water temperature of water running over evaporator plate.This sensor is located in the water supply tube that runs up to the top of the evaporator plate. just pull the sensor out of the tube and replace it.
If you want to fix it yourself go to partsexpress.com and buy a new headphone plug. You can go to radio shack, but their headphone plug is very large but you won't need to solder anything. Cut the wires and strip off the plastic. You will see very small wires coated in red and blue if I remember correctly. You will need to separate all little wires so the colors are together. The color coatings need to be removed. Put them in the flame of a lighter for just a quick second. The coating will burn off. Scratch off the excess with your fingernail.
You will need to plug the new headphone plug into an ipod and touch the wires to the connectors to figure out which wires are for the left and the right speakers.
Solder the wires to the new headphone jack. You will find the partsexpress jacks are much better than the original.
If you use the radio shack plug you may want to put a little hot glue with a glue gun around the wires before you close it put or the wires will pull out easily. The parts express plug, link below, has a tight grip on the wires and there is no need for glue.
