When powered up ds displays warning screen, lower screen touched to continue then lower screen does not respond to anything. By using buttons can navigate around bottom screen.
Sounds like you should try recaliberating the touch screen. Calibration must be done with a stylus. Please note: Using a unlicsensed screen protector can lower the sensitivity of the screen, making calibration difficult. If the problem you are encountering started happening after installing a screen protector, this may be the cause of the problem. Remove all games from the Nintendo DS. Turn the system on by pressing the POWER button. Press the A Button when the "Touch the Touch Screen to continue" message appears. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button. should look like this :
Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button. should look like this:
Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves. You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings. hope this helps
Recalibrating the Touch Screen Remove all games from the Nintendo DS Lite. Turn the system on by pressing the POWER switch. Press the A Button when the "Touch the Touch Screen to continue" message appears. When the main menu appears, use the Control Pad to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves. (Note : You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.) When complete, four squares will appear, allowing users to test the touch screen sensitivity. (Testing is optional.) Tap the "Confirm" button in the lower-right corner. Wait for the the confirmation message to disappear, then tap "Quit," then "Yes" to exit. The unit will shut down automatically to save the settings.
double check that both cable/ribbons are connected properly to the motherboard, the small thin ribbon which curls over the top of the motherboard is the one which powers and reads the touch screen so double check this!!
if this is all in fine then im sorry to say your touch screen is broken and will need replacing!
Be sure that you're using only the bottom screen of the Nintendo DS Lite with the stylus. The upper screen is not a touch screen.
Unlicensed screen protectors can lower the sensitivity of the touch screen. If the problem you are experiencing started happening after you attached a screen protector, you may want to remove it. Please note that some screen protectors can leave behind a residue that may be difficult to clean. If you are planning on removing a screen protector that has been placed on your Nintendo DS Lite
If the touch screen is not responding when touched, or the accuracy of the screen is off, you may need to recalibrate the touch screen.
If the touch screen is not responding properly, hold the Nintendo DS at an angle so that you can see where the edges of the Touch Screen meet the housing of the system. Look around the entire edge of the Touch Screen for any foreign material (such as crumbs, etc.) that may be wedged in between the Touch Screen and the housing of the DS. Foreign material in this area can cause the Touch Screen to work incorrectly. If there are any visible particles, clean the screen.
If the above steps did not help, there is a problem with the system and it will need to be repaired.
