Posted on Nov 11, 2010
Transistors 571134/7922 and 561049/7917 - Audio Players & Recorders
The type of audio power and the number on onkyo A917 amplifier
Hi
Usually there are 2 transistors for each channel, if you don't know the numbers on the transistors.
there is another way to get as close as possible to have equal or similar to the same type of transistors (NPN/PNP)
example: 2SA is PNP transistor.
there are (2SA/2SC) transistors and there are (2SB/2SD)
complementary transistors
1: you have to know the supply voltage for the transistors
2: choose transistors that it is equal to the current and voltage that suits the supply voltage.
follow this link to find suitable transistors.
be aware and be careful that there other parts you need to check on the power amplifier circuit, resistors,capacitors and drivers etc...
I would suggest (2SD1047/2SB817)
http://www.smcelectronics.com/DOWNLOADS/COMPTRANS.PDF
Good luck
Hope this helps
2helpful
Sony xplod 1200 watt amp quit no kind of protect lite on please
short answer yes... Long answer... Amp Failure: There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors: In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals. Note: I used the terms short and open on the previous paragraph. A short (short circuit) is a path through which current flows that should not be there. An open (open circuit) is a break in the circuit. It is most likely the power supply that has taken a ****.
2helpful
401s Rockford Fosgate Amp. Not turning on. No power light. Pos+ and GR- are solid. Thought it may be remote, so tried running a wire from the POS+ to REM to test it, no luck
Amp Failure:
These repairs are best left to a repair tech familiar with car audio amplifiers. Check with your local shop to get a reccomendation. If the light isnt even coming on, chances are your input or power supply has been taken out.
1helpful
No sound coming from speakers Blaupunkt GTA470 Amp
Amp Failure:
I have an audiobahn A8000t amp with the protection light on
Note:
I have a fosgate 301x with power to the amp but none coming out
Note:
There are no internal fuses on any car audio Amplifier. Servicing will be required.
Well my amp comes on but it doesnt give out like bass power or its jus not working like it use to the light comes on orange or red
Note:
1helpful
Amp turns on just fine but no sound comes out
Amp Failure:
Seems as you have blown an output. Seek repairs.
1helpful
2answers
Benq lcd c5707 transistor issues
You need transistors with hfe greater than 300. They are harder to get and you should use the producter`s original transistors 2sa5707.
Transistor
The first letter: A = Ge material semiconductors, B = Si material semiconductors, C = GaAs material semiconductors, R = Compound material. The second letter: A = Diode (low power, signal); B = Diode (variable capacitance)); C = Transistor (low power, audio frequency); D = Transistor (power, audio frequency); F = Transistor (low power, high frequency); L = Transistor (power, high frequency); R= control and swithching device); S = Transistor (low power, swithching); T = thyristors; U = Transistor (power, switching); X = Diode (varactor, multiplier); Y = Diode (rectifier); Z = Diode (zener). So the BC547 is a Silicon low power, audio frequency transistor. Hope that helps!
Sep 26, 2007 • Nokia 1100
 Grubhead
Grubhead
SmartAviator
SmartAviator
