SOURCE: changed out blower motor on elect furnace.the old
hmmm . you better check on that before firing it up ... normally the colored wires are for different speeds .. only one speed can be connected at a time .. usually the high speed winding is used for air conditioning and a lower speed winding is selected by a relay for heating .. ... the way the capacitor is hooked up determines which way the motor will turn .. your old motor with just 3 wires was probably a single speed motor .. normally the black wire will be connected permanantly to one phase .. the other phase then goes to the selected speed winding (color of wire) .. one goes to the starting capacitor . the others even if not connected will be hot electrically so need wire nuts to prevent shorts ..
SOURCE: I have a Dayton 36
GRAINGER.COM THEY HAVE A TECH LINE, BUT ON THE MOTOR LABEL IT SHOULD HAVE THE WIRING DIAGRAM .. GOOD LUCK AND I'FN I WAS ANY HELP PRAISE IS APPRECIATED .. SO VOTE JAY MOTORWIZJ
SOURCE: put dayton split phase 1/2
look carefully at the label!!!. there is a diagram on how to reverse the rotation.
SOURCE: i just bought a dayton model 4m098j direct drive
The brown wires go tto the capacitor...
Here is the page
http://www.grainger.com/Grainger/wwg/search.shtml?searchQuery=4m098&op=search&Ntt=4m098&N=0&sst=subset
On the top right of the page you will se that the cap. is a REQUIRED accessory....buy it and hook it to the brown wires and the motor will run...
heatman101
SOURCE: How do you wire a dayton electric unit heater?
tengo un motor dayton y nesesito darle un mantenimiento me podrian fasilitar un manual de ma
