The problem is in the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing. Verify this condition by bypassing the said components. Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect the power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Indicate the exact model number of the dryer should you need further assistance.
Yes its helpful as you said that, and i have done bypass it the thermal cut-off and the high-limit thermostat 250 F then i start to turn on let it run about less than a minute and i see it heat up. At this time i'm still waiting for both parts ordered online to come and receive. When i receive the parts and will put on then i'll let you know the result, but i am sure 100% that will fix it and its the problem with thermal cut-off (it cut-out) and high-limit thermostat as you said, right. May i appreciate and thanks you very much, Jahn27 and this Service as well.
