IT APPEARS AS THOUGHT THE RECORDER DOES NOT FORMAT THE DVD-Rs. HELP
Comments:
Jun 16, 2008
- I HAVE PURCHASED MEMOREX DVD+R AND MAXWELL DVD-R.
WHEN I CLOSE THE TRAY, I GET A "NO DISC" MESSAGE OR A RED CIRCLE WITH A RED SLASH.
Jun 16, 2008
- ALSO, I CANNOT FIND A RESET FEATURE ON THE REMOTE CONTROL
Jun 16, 2008
- THE TROUBLE SHOOTING SECTION OF THE MANUAL DOES NOT ADDRESS THIS SITUATION
Jun 16, 2008
- I HAVE SPENT TWO DAYS ATTEMPTING TO FIX THIS SO I CAN RECORD SEVERAL DVDs. NO LUCK. ANY OTHER SUGGESTIONS?
Jun 16, 2008
- ANYBODY ELSE HAVE A SOLUTION?
Jun 16, 2008
- THAT WAS SUGGESTED BY THE PREVIOUS ASSISTANCE. I AM UNABLE TO FIND A METHOD OF RESETTING THE RECORDER. DO YOU KNOW THE PROCEDURE, BECAUSE IT IS NOT IN MY MANUAL
This problem of yours just need to be isolated so we can get to the final fix, as I check the some information about your Recorder I may suggest you to get a DVD-RW instead of a plain DVD-R disc. Can you please inform me also if you that player/recorder can read a DVD with movie or files inside it.
Hope it helps........
Comments:
Jun 16, 2008
- If you need to, you can reset the Recorder to all its factory settings. Select ‘‘Set’’ icon then press ENTER.
Jun 16, 2008
- Hope that is the correct way to reset your recorder, just inform me if that one dont work , good luck
If you think the unit is not prerforming as it should,
Check your warranty information.
If you are still covered under warranty (usually 12 months from purchase), contact the manufacturers (listed in the booklet), and return the unit according to their policy.
You should not be charged for repairs/ replacement, but could be billed for postage.
Make sure you use recorded/ signed for delivery to prevent loss /damage issues.
you first check what kinda of media you are using. Is it a +or- dvd-r. Your problem most likely is in the fact that the unit you are using only likes specific disk's. make sure its a 8x dvd+r.
Comments:
Jun 16, 2008
- also if by format you mean erase everything off a previously recorded dvd. Thats not how a dvd-R works, Thats how dvd-RW works. If the dvd has already been burned onto once then it can no longer be burned onto. Unless it is a multi-session but that is not the case here.
Jun 16, 2008
- So what id like you to do so i can help solve your problem. Is get a brand new DVD+R and try to record to it. If it fully records the unit is fine. Which means you just need to go DVD+RW disks from your local computer store. Those are the type of media which your recorder will be able to format. Note* that they only should need to be formatted after having data "Burned" onto the DVD+RW. Let me know how the dvd test burn goes. So i can further assist you with your problem
Thanks Nathan
Jun 16, 2008
- do you still need assistance?
Jun 16, 2008
- have you tried everything that i see me and leethedeuce said. definetly try another brand dvd. Maybe even a lens cleaner to clean the lens.
it is not recognizing DVD-R's and does not formatting it ?
happening on any-brand DVD-R's ?
Comments:
Jun 16, 2008
- Manual says : Recordable Media : DVD+R · DVD+RW
Jun 16, 2008
- Since already spent time and money on different DVD's (check if one of them disc's is 8x just to be sure) and the unit is NOT reading the media (as it supposed to)
If it is still in warranty, Service or Return or Replacement from the manufacturer.
First try a different brand DVD-R as that is a common issue as not all rewritable discs work in all burners. Keep me posted as I will list some other common solutions to this problem, Thanks, Lee
Comments:
Jun 16, 2008
- are they 8x DVD+R??
Jun 16, 2008
- Try a different brand DVD+R that is 8x.
Jun 16, 2008
- As far as I know there is no reset. The unit most likely either dirty or broke. First try a DVD Lens cleanr. If that doesn't work either have it serviced or a better solution would be to just relace it if the unit is out of warranty. Thanks and good luck, Lee
Jun 16, 2008
- marked, if you would have read or researched the item your suppose use DVD+R that are 8x. Good luck, Lee
I want the front board because my has shorted out the part number on the board is 59-128-02000. I...
(More)
I want the front board because my has shorted out the part number on the board is 59-128-02000. I don't care if it is used or not
I have one disc out of three that my Windows Vista Home Premium doesn't recognize. Sometimes I will...
(More)
I have one disc out of three that my Windows Vista Home Premium doesn't recognize. Sometimes I will hear the drive trying to do something a couple of times and then it stops. I downloaded the freeware version of "CD Recovery" and still my disc wasn't recognized. Sometimes I get a popup with three options asking me if I want to burn a DVD and I don't remember the other two options. I have cleaned the disc with alcohol and then tried the Pledge solution but nothing has worked yet. Does anyone have an idea on what the next step is? I have also tried to get someone else's computer to read this paricular disc but that was unsuccessful also.
i put my dvd+r in my dvd player and the only thing that comes up is mp3 or jpeg i can't play the...
(More)
i put my dvd+r in my dvd player and the only thing that comes up is mp3 or jpeg i can't play the movie i put on there
