Heat: thermal fuse attached to the exhaust duct on the back panel of the gas dryer,usually surrounded by a black resin material situated in a housing made of white plastic, if there is a lot of lint built up it will cause it to blow
Spin: belt , motor, switch
here is a website that will help:
http://www.applianceaid.com/gas_dryer.html#noheat
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
l;
