SOLUTION:there is ahook that sits on the leftside and a spring it sits on to give it some leadway i checked to see that it doesnt break, there is also a section of the carriage it slip thru i also try to get it re attached. remove the catridge then put it back and place it properly making sure its making proper contact
HI
if its stock, the only thing that you can do is to dismantle the parts so that you can access the tanks, if its still within the warranty might as well call canon support for a replacement or service. resetting will not actually resolve this, honestly this is a hardware issue already, but if you want to take the chance you can open it up. but if within warranty dont open it this might void the warranty status of your printer.
Justs makes a grinding oise and will not move
Cannon PIXMA MP830 printer.. ink Cartridge jammed in tank holder and will not move..jusst a grinding noise...how can i get it unjammed> first suggestion to re set did not work
