Televison & Video Logo
Posted on Jun 09, 2008
Just got a new LG 42 " tv have hooked up video and it will play tapes but not able to record for some reason. Scart to Scart connection from vid to AV 1 on tv.
A
Anonymous
Anonymous
Level 1:
  • Contributor 68 Answers
  • Posted on Jun 10, 2008
Anonymous
Contributor
Level 1:
Answers
68
Questions
0
Helped
19718
Points
77
Scart is not always two-way, if that is the way you have hooked it up. A lot of newer appliances have one-way scart connectors, and the vid/av plugs are also wired in one direction.
Are you trying to record from the bult-in tuner to the video? Then you would also have to wire from the av-out of the TV to the video in on the video/dvd... essentially doubling up on the cables.
How do you hook up a VCR player to a TV without a cable box?
Common connection is a scart cable. You will NOT be able to record TV on video tape anymore because the transmissions are now all DIGITAL and VCR's are only ANALOGUE. You WILL be able to play existing tapes if your tv has analogue capability.
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Problems with Philips vhs recorder/dvd player
You only need coaxial cable to pick up TV stations broadcast via an aerial. If your TV has sockets to connect via HDMI or SCART, then any players can be connected via them. So if the adapter box picks up TV signals, you connect the main aerial cable to that and it should have a coaxial out socket, that should be connected to the aerial in of your TV. If you are recording to an analogue video from the adapter box, then that will need to be connected via a scart socket or other connection.
No sound when playing a tape in the rca vcr player
If it's connected with a scart cable, then there may be a bent pin or broken wire.
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
1helpful
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
1helpful
Bought a new 42' flat - "No Program or Weak Signal"
Hi,you have not said weather you are using a scart lead(euro connecter)or an RF lead,if you are using the later don't,please connect the vcr to the tv via the scart to scart euro connecters,use a good quality scart lead(the thicker the better)as the thicker ones generally are 21 pins connected meaning it should be auto switching so as soon as you play a tape it will come straight on.
Zenith xbr716
ALL cable is digital.
What type of TV do you have? Does it have any scart conections on it? If not connect the Cable box with a scart lead to your VCR select the AV channel on your VCR, connect your VCR to your TV via the RF connection, (if it has not got one, its not a TV, its a monitor). Tune your TV in to the video channel.
You do not need an RF modulator for a home TV setup, whoever told you that is a fool.
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
