Contributor
- Posted on Oct 19, 2010
Re: Emergency brake light won't go off. Now leaking...
This brake warning light has dual functions,1 it tell you emer brake is on 2 it tells you you have low brake fluid leval,you said you see fluid and your resivoir is low,this means you have a leak in the brake system,and should not drive untill leak is found and problem is repaired
