Dell (E210882) Motherboard Logo
Posted on Jun 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell Dimenion 3000
Hello, my Dell won't turn on. The green LEd on the Motherboard is on, but NOTHING happens when I hit the front panel power switch. I checked the switch with am ohm meter, but it is okay. The PC is just dead apart fro that litle green LED on the motherboard.
Thanks!
Ron
  • Anonymous Jun 15, 2008
    I have the E210882 MB in a dimension 3000. Recent electrical storm shut it down. Now power switch non-functional. First suspected PS. Replaced PS. Same - switch non-functional. Tested switch - OK. Shorted green to black on MB connector. Get power! Understand that the power is controlled from front panel switch through power control chip on MB??? Most likely suspect at this time. Wish I could find the schematics for the MB. Maybe a simple diode replacement vs. MB replacement. MB ~$195.00 from Dell! Maybe by-pass the power control chip? Any help is appreciated. I'm an experienced tech. doing this for a friend on an out of warranty PC. Also, purchased a new UPS for friend.
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on Jun 04, 2008
Anonymous
Expert
Level 2:
Answers
50
Questions
0
Helped
19488
Points
113
Sounds like you need a new motherboard. Try to reset the bios with the jumper (or remove the battery and unplug it) and see if that does anything, if it doesn't start looking for a new mb.
2answers
The led on the front won't light, and I have power connected, but nothing. Is there a reset somewere?
I am assuming you are trying to power up an installed motherboard, based on the category selection. You say that you have power connected. That means that you have connected the 20 (24) pin main connector and the 4 or 8 pin CPU power connector to the motherboard. Have you connected the front panels controls to the motherboard header? There are connections for the power switch, power LED, HDD LED, reset switch (optional). They must be connected in order for the motherboard to start. THe HDD and Power LED connections are polarity-based, so if you hook them upo backwards, their respective LED will not light. The HDD LED plug is usually red and white with the red being on the positive (+) terminal. The Power LED plug is usually green and white with the green wire going to the positive terminal. The power switch and reset switch wires can be connected either way as they are not polarized.
Nothing happens
Hello download the manual here:
http://www.msi.com/product/mb/890FXA-GD70.html#/?div=Manual
And check the front panel connections again.
You might have connected this the wrong way.
Good luck
I have a broken Dell Precision 470 Workstation. The symptoms are as follows: Won't power up; Flashing yellow power LED on front panel; Blank STR_LED on motherboard; Yellow AUX_PWR LED on motherboa
Flashing front powerlight is often a result of a faulty powersupply, try another powersully on the pc and see if the problem gets solved. I've seen a few of these cases personally.
Not power on continiously front panel led on off
Hello Asam,
Please check the connection of front panel led on the motherboard. If the connections are ok then the front panel led gets fused.
Will not turn on when power button is Dell Inspiron 518 will not turn on when power button is pressed. Green LED on back of powersupply lights and orange LED on motherboard turns on. No fan operation on...
Green LED on back of power supply indicates it's getting power. That does not mean that it's distributing the power voltages to the computer. You could have a bad power supply or a bad motherboard. Just to make surethat nothing else is causing the problem, remove any PCI cards like modem,video card, sound card, etc... Remove the memory modules and disconnect cablesto CD/DVD drives. Look at the USB ports to see if any are damaged.
During a recent thunderstorm, the power fluctuated and my dell dimension 3000 turned off. There was popping sound and now I cannot power on the computer. When I take off the side panel, I can see a green...
The popping sound is most likely your power supply or something on your system-board like a capacitor.
If the problem is only the power supply:
If you want to see if you can salvage it try just replacing the power supply. The part is around forty dollars. You can google "Dell Dimension 3000 250w power supply" to find a deal on a power supply.Here is a link on how to replace the power supply in that computer.
http://support.dell.com/support/edocs/systems/dim3000/en/SM/parts.htm#wp1075727
Hope that helps.
Joel
Motherboard won't boot: no noise, no nothing...
Shorting the two leads will work but don't keep the two wires together. They are not ment to stay connected. Consider replacing your cases ATX power switch. Take a look at the link provided for a new switch;
http://www.cables4computer.com/Cases_and_Enclosures/Mid-Tower_PC-Cases_ATX_Push_Button_Power_Switch.html
The green LED on the motherboard means the board is in "Stand by mode". This green LED uses 5V DC to light the LED. After replacing your PS back into your system it may function just fine.
Good luck.
Mike
My motherboard out of a dell optiplex gx260 the board it self is part number ASSY-3M537, I want to put it in a atx case I am worried it won't work. on the board I don't see how to hook up the power switch...
This should be the front panel header configuration of that particular motherboard.
6-8 (red) is your power sw
2-4 (green) is your power LED
1-3 (yellow) is your HDD LED
5-7 (purple) is your reset sw
black is not connected
The motherboard should go into a custom case no problem.
Regards.
1helpful
E210882 socket type 775, PCIe, DDR2 - Will not turn on
On the Dell board, the
CORRECT pinout for J8H1 is as follows:
1-3: HD LED (#1 is +)
2-4: PWR LED (#2 is +)
5-7: PWR ON/OFF
6-8: RESET
5,16: +5V
10,11,14,15: not connected
12,13: GND
Regards.
No power
check ur smps and power connector Mother board ok
next power switch for on/off ok check front panel byy
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
