Motorcycles Logo
Posted on Oct 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1988fxstc. Oil is blowing out of what looks like a oil tank vent hose that ends down by the rear tire. This is not the drain hose, but looks like a venting hose that is open near the rear tire. Anyone know what is going on? I recently changed the oil using HD synthetic oil for the first time. Could this be the problem?
Anonymous
Level 3:
Brigadier General:
  • Master 4,565 Answers
  • Posted on Oct 18, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
4565
Questions
0
Helped
2156230
Points
14358
Without seeing the bike, I would guess that this is the crankcase vent. Originally, the crankcase vent tube came up from behind the oil pump and went to the backside of the air filter. A lot of owners changed the routing of this hose due to oil being blown into the air filter. They simply remove the metal part of the tube and replaced it with a short open ended hose running back and ending just forward of the rear tire.
As for the oil blowing out of the tube, it depends on how much oil blows out of the tube. If it's just a mist that will sometimes coalese into a droplet, this is about normal. But, if it's a steady drip or flowing oil, this is not right.
If the mist is heavy, this could be caused by excessive blowby on the rings creating high crankcase pressures. The use of synthetic oil should not increase the blowby unless the rings are in poor shape, then it will. The use of synthetic oil seems to aggrevate any minor leak turning it into a much larger leak.
If the oil is coming out in a steady stream or pumping the oil out of the engine, you proabably have sheared a key in the scavenge gears of the oil pump and it's not pumping the oil back into the oil tank.
Now there is a vent hose on the oil tank but it should be routed to a fitting on the crankcase that is located just above and slightly behind the top of the oil pump.
Good Luck
Steve
1helpful
Oil leak
If the hose comes out the top of the transmission, this is the transmission vent line.
Make sure the line doesn't "dip" anywhere alone it's run, causing a low area where residual oil would "pool", then blow out under pressure.
Also, make sure transmission fluid isn't over-filled.
Location for engine oil drain plug and where is the plug to drain the transsmission 200 fxstd deuce
The oil drain for the engine oil is a hose that comes off the lower backside of the oil tank on the right side of the bike. It goes down behind the transmission and comes out on the frame down low on the swingarm about where the rear end of the shocks connect. It has a plug in the end of the hose. On some of the later models, this hose connects to a crossmember on the frame with the plug directly on the underside of the hose where it connects. The transmission oil drain is a small pipe plug, 1/8" pipe plug, on the end of the transmission just below the chrome release mechanism housing behind the exhaust system. It takes a Torx key to remove the plug. The transmission holds 20-24 ounces of H-D Syn3 20W50 synthetic engine oil.
Good Luck
Steve
3helpful
93 Fatboy oil leaking from vent tube at air filter. oil level is good, not over filled, oil will cover the oil tank on a 100 mile trip
On your '93 model, the crankcase vent is down low on the engine behind the oil pump and it runs up to the air filter through a metal and rubber hose. I don't know how many miles you have on your engine but it you're getting any blow-by on the rings, this will increase the pressure in the crankcase. Most people simply re-route the crankcase breather underneath the bike and plug the hole on the backside of the air filter. Replace the metal line with a rubber hose and put a small filter in the end of the hose. Route the hose back behind the transmission and attach it to the transmission mounting plate just in front of the rear wheel.
This was the way the older Shovelheads were done from the factory for years until the EPA made them start running the crankcase vented air through the engine. In 1994, Harley went to the "head breather" system and moved the crankcase vents to the heads. Still, the oil mist in the vented air builds up in the air cleaner on these models as well.
Good Luck
Steve
Oil change 2001 softail
From the right side of the bike, look at the very lowest point of the oil tank. Back behind it is a hose that runs down behind the transmission and comes out down below the clutch release mechanism, that chrome cover on the right end if the transmission. The hose goes right down by the frame and behind the exhaust system. It either has a metal plug in the end of the hose or the hose connects to a crossmember of the frame. If it's connected to the crossmember, feel on the underside of the crossmember and you should feel a drain plug. Drain the oil and refill the tank with three quarts of 20W50 oil.
Good Luck
Steve
2answers
How do you change the motor oil on a 2001 FLSTFI
In my first attempt to change my engine oil, I drained oil from bottom of my 2001 Fatboy, from the plug on the right side towards the front of the engine, just below the Twin Cam Cover and floor board (see attached picture) look at dark spot where plug is located, only approx 4 oz drained out, where is this from? How to I refill that oil?
P.S. I did find the right one mounted on the right side towards the rear of the engine, so oil is now changed. _1035.jpg
2helpful
Changint Oil on my 2001 Fatboy. Pulled drain plug and a half a cup of oil drained out. Pulled dip stick to see oil tank is still full. Disconnected drain line from tank leading to motor. Found it to be...
Sound like you pulled the wrong plug to me. The oil drain plug in under your bike. Look at the oil tank from the right side of your bike. Near the rear of the tank, there's a large hose that runs downward towards the rear of the transmission. It continues down and looks like it connects to a crossmember on the frame. If you'll look under that crossmember, you'll find a plug that uses an Allen wrench or hex key to remove.
Do not remove the oil line that goes from the tank to the engine. However, you said that you found it to be plugged. Plugged with what? If the oil infeed line got plugged, it's because something has gotten into the tank. Drain the tank and check to find out what is inside the tank.
Good Luck
steve
1991 fatboy
There is a large diameter rubber hose on the right hand side of the bike. At the end of this hose is a plug. The hose ends down on the frame to the rear of the chrome transmission end cover. Loosen the hose clamp and remove the plug to drain the oil tank.
1helpful
I think I have identified the sump drain plug on my 2003 Heritage Softail. Is it a hex head plug on the bottom RH side of the crankase? If so, it is screwed in ridiculously tight. I don't want to strip the...
No, I don't think you're on the oil drain plug. Harley motorcycles use what we call a "dry sump" oil system. This means that the oil is not carried in the engine but rather in a remotely mounted tank. In a wet sump engine, the oil is in the bottom of the engine, like on a Honda or in your automobile.
On your Softail, find the oil tank. Now look for a hose that comes from the rear lower left side of the tank and goes down to the frame just below and behind the chrome end cover on our transmission on the right side of your bike. There is probably a clip on the frame that holds the hose and there is a plug in the end of the hose with a hose clamp on it. This is the oil drain hose. Loosen the clamp, remove the plug, and the oil will drain out of the tank. This is where it used to be. I'm not being sarcastic but I don't often work on the later models. I work mostly on the models made prior to the year 2000. I hope this helps.
2helpful
2answers
How do you drain the engine oil out of the oil tank on a 2004 883 harley davidson sportster
There is a hose that comes down between the rear down tubes on the frame, it goes back and attaches to the the frame. It doesn't look like it should be a drain hose but it is. Make sure you bring the temp up on the bike before you drain the oil and check the oil tank before you refill, I usually need to use a turkey baster to remove the last of the old oil out of mine. When you refill the tank make sure to only fill it to about hal lf way between the low and full marks on the dip stick to reduce blow by. Also don't forget to put about 4 ounces in the oil filter to prime the motor.
1helpful
On S50 Suzuki Motocycle I have an oil drip from a rubber tube that looks like it comes from up near the air cleaner and exits below the bike. Any ideas before I start taking the seat, tank, etc. off?
The air cleaner(filter) also filters crankcase blowby . Oil accumulates in filter box and drains. The draining is to prevent oil from being drawn into intake an should be addressed by servicing air filter and cleaning out the box. Rapid and excess oil in filter is a n indicator that blowby is considerable. Hardrabbit starts and sudden accelerations play a big part in ring wear and blowby. I've noticed the use of filter sponge placed, not stuffedm in crankcase vent hosebef ore filter housing will separate oil from fumes before they get to airfilter and oil will drain right back into engine instead of collecting in air box. Some crankcase vents are baffled and have a seperation medium factory installed at the enngine end if vent hose. Do not plug the drain or crankcase vent hose. major leaks will sevelope. Over reving will also cause greater oil misting that is carried out the vent with the air. Good luck - note! rapid throttling affects fuel burning eficciency and tends to break down needed cykinder wall lubtication, hastening ring wear. have fun, be safe.
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
