Amana Easy Reach Plus ABR1922FES Stainless Steel (186 cu ft) Bottom Freezer Refrigerator Logo
Posted on Oct 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice maker does not work - Amana Easy Reach Plus ABR1922FES Stainless Steel (186 cu ft) Bottom Freezer Refrigerator
Anonymous
Level 3:
  • Amana Master 43,501 Answers
  • Posted on Oct 17, 2010
Anonymous
Amana Master
Level 3:
Answers
43501
Questions
0
Helped
10845433
Points
101584
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
I turned the ice maker off now I can't get it to turn on and work it freezes cubes but won't dump them in ice been
Ice maker harvest cycle is not working. Jammed timer in Ice maker unit.
Remove the wire harness of the ice maker and put it back after 5 minutes. See next day whether it is working.
If not still working. You did the right needed thing at the wrong time to shut off the ice maker. You will have to replace the ice maker.
Ice maker units are very sensitive units. Sorry to say.
GE Profile Model PSS26LGSC Ice maker not working
Did the ice buildup appear to resemble the water overfilling the top of the ice maker? The only thing that I believe that may work is removing the ice maker, clean the excess ice buildup.dry and reinstall the ice maker and see it works. If the ice is above the normal level the ice can cause the motor that pushes the ice out of its slots to strain more than the gears or motor can handle stripping the gear or damaging the motor beyond repair, When harvest takes place the first thing that happens is a heater below the ice maker warms the cubes a little just enough to allow them to slide out of their slots and fall into the ice bin. The ice make for your model does not have replaceable parts and if bad or damaged it is less expensive and time consuming to by a new ice maker. If the water fills above the top of the ice maker it is usually the fault of the water control valve not closing all the way once it fills the ice maker after each harvest. Did water refill the ice maker when you cleaned it? Did the water overfill after you cleaned out the ice maker? What I am asking is water over filling ice maker again after you cleaned out the excess ice? If the water continues to flow from the WR57X10032 Water Inlet Valve
heatman101
uiouio67
1helpful
heatman101
fdfdfs43
1helpful
Ice maker is not working. I hear water running to ice maker but no ice is being produced
heatman101
kjjhfkj
4helpful
2answers
Ice maker will not make ice, water dispenser is working
heatman101
oypyiooiyp
1helpful
ICE MAKER NOT WORKING
heatman101
2helpful
Refrigerator ice maker stopped working
heatman101
mnnmbnm
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
