I have a Kariba brand, all-in-one washer/dryer on my boat. Recently,
the spin cycles have stopped working. When loaded and turned on, it fills with
water and washes as usual but when it gets to a spin cycle the tub stops, the
water get pumped out (without spinning) then the machine continues on to the
next cycle. When empty, the machine goes through all cycles, including the spin
cycles, as expected.
Where should I begin trouble shooting this problem?
Fred1
SOURCE: Washer doesn't agitate
sounds like your washer went mellow on you(doesn't get agitated, right)?
ok. enough humor.
sounds like there's a problem with the motor/belt/control board in that order
SOURCE: Washer fills, drains, & final spin
I had the same problem and ended up replacing the control board which solved it. Contact Westland Sales at 800-356-0766 ext. 5 for tech support.
SOURCE: unit runs good through wash cycle then while in
Sounds as if the drain pump is not ejecting the water fast enough. Did you notice of the washer is draining more slowly than usual or at all?
SOURCE: I have a 2100 Splendide vented washer dryer in my
Please check this link bellow to have an indepth knowledge to your problem....
http://www.repairclinic.com/Washing-Machine-Troubleshooting
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
SOURCE: for wd802co the machine is
have you checked the water pump that draws the water out of the machine there maybe an obstruction like a sock or something. Make sure the pump is turning freely there maybe a blockage there. Also check the exit hose as well. Gain access from the rear.
My w/d will not spin on the wash cycle. It does spin on the dry mode.
Ed King
[email protected]
