Xerox WorkCentre 4150 Black and White Copier Logo
Posted on Oct 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know what the part number is for the maintenance kit for work centre 4150
Anonymous
Level 3:
  • Master 1,110 Answers
  • Posted on Oct 12, 2010
Anonymous
Master
Level 3:
Answers
1110
Questions
Helped
544945
Points
4088
Here is a link to all the available parts and supplies for the Xerox 4150. This includes part number, yields and even pictures.
http://www.precisionroller.com/search.php?q=xerox+4150
Good Luck and Thank You for using Fixya.
Xerox 8560 displays replace incorrect maintenance kit
Was this a new maintenance kit? If it was new, try putting the old one back in, if it reports the same message, the pivot plate will more than likely need replacing. If it displays the original message i.e, replace maintenance kit, then the fault is with the new maintenance kit. Do check you have been sent the correct maintenance kit for your machine, part number should be 108R00675 for standard and 108R00676 for the extended Phaser 8560 printer and Phaser 8560MFP kit.
If it is the original maintenance kit and the error just appeared, as I am assuming you will have already tried re-seating it, the problem is likely to be the pivot plate again.
Hope this helps.
2helpful
My hp laserjet 4015 is displaying an error 50.3 after printing smarged copies
Thank you for contacting FixYa with your printer inquiry.
The 50.3 is a fuser Temperature error. If your pages have toner and image but are smudging or smearing you know the fuser is not heating and needs to be replaced.
If your printer is still under warranty contact HP Customer Care for warranty replacement of fuser part numbers: RM1-1082 for 110 volt, RM1-1083 for 220 volt. (888) 999-4747.
If your printer is out of warranty, suggest you purchase a maintenance kit part # CB388A HP maintenance kit for LaserJet P4014 P4015 P4515, includes other needed high wear parts.
Excellent Illustrations:
http://www.printertechs.com/tech/mkinst/P4015/mk-p4015-2fuser.php
Maintenance Kit Contents:
Contents
1. What is included in a LaserJet P4014 P4015 P4515 maintenance kit?
2. Fuser installation.
3. Transfer roller installation.
4. Cassette feed/pickup rollers.
5. Tray 1 (manual feed) pickup rollers/feed rollers.
6. Reset the maintenance count.
Please rate this solution and post a comment if you need additional assistance.
2answers
Xerox work centre 4150 screen states faulty fuser module. Can't seem to find part...Help
That is in fact a bad fuser which must be replaced (part# 126N00321 for 110v). Replacing it is simple, open the right door and remove the 4 screws that hold in the fuser. Make sure the machine has been off for awhile because the fuser my be hot. Here is a video that shows you how. Hope it helps, and thanks for using fixya
1helpful
Where is the maintenance kit on hplaserjet 4345mfp
After printing 215,000 pages, the MFP alerts you to order a maintenance kit. The message can be
temporarily cleared for approximately 10,000 pages by using the CLEAR MAINTENANCE
MESSAGE
item on the RESETS submenu. When the page count reaches 225,000, you can no
longer clear the message and you must install the maintenance kit. To check the number of pages
that the MFP has printed since new maintenance-kit components were installed, print either a
configuration page or a supplies-status page
the maintenance kit is Fusing element , pickup rolls for all trays, and transfer corona
To reset the maintenance-kit counter
Turn the MFP off and then on.
2 When the memory count appears on the control-panel display, press and hold 6 until all three
LEDs flash once and then stay on. (This might take up to 20 seconds.)
3 Release 6 and then press 3.
4 Press 6 to select NEW MAINTENANCE KIT.
5 The MFP completes its initialization sequence. The maintenance-kit counter is automatically reset.
SMART KIT DRUM CARTRIDGE
Call 1-800-821-2797. Thats a machine software issue..
Here is the note on it.
Problem:
The DRUM and TONER cartridges are not installed correctly. Web page indicates replace %0 empty cartridges. The Machine doesn't copy. Cause:
Firmware and work-process problem. . Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Don t worry about cartridges. They are safe. Upgrade firmware. The message goes away and machine copies
1helpful
2answers
MAINT. KIT
Here is what you need. Its is easily replaced through the maintenance drawer on the right side of the printer Part # spacer.gif Description spacer.gif Capacity2 spacer.gif Price spacer.gif spacer.gif spacer.gif 108R00656 spacer.gif Standard-Capacity Maintenance Kit, Work Centre C2424 spacer.gif Up to 10,000 pages spacer.gif $99.99 spacer.gif spacer.gif spacer.gif 108R00657 spacer.gif Extended-Capacity Maintenance Kit, WorkCentre C2424 spacer.gif Up to 30,000 pages spacer.gif $149.99
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
