connect video and audio to tv - when it works, split audio to both units (tv and surround system), reason for it might be ground problems or sync failure
No variable audio out means that whatever the volume is at on the TV it will output that level from the TV. So if you have your surround sound on and if you change the volume on your TV it will also make your surround sound louder with out having to turn up that volume on your surround sound, but if you have your volume muted then so will the audio out. So if it is a fixed audio out then no matter what level you have the TV set to it will output the same level. If you just want audio to go to your surround sound then just hook the video cables up to your TV and the audio to your surround sound. I would guess that you are using Red and White cables... If you are that only gives you left and right audio. Not surround sound, so you would want to run optical, HDMI, digital coax, or the analog 6 channel audio cables.
Sounds like you have it hooked up properly. Be aware that if there is not a digitally encoded signal for surround sound [they don't always do that] you simply won't have surround sound. Usually there is a mode in your receiver/amplifier that will allow you to simulate surround sound. An example of that would be "theater" or "hall" sound. Try it with a DVD known to have surround sound encoding [most of them do] and see if it works that way. If it doesn't then check your owners manual for information about how to make sure that feature is actually turned "on".
Not sure how you're hooked up or what model TV you're using. If you mean the TV sound through RCA cables is the source and you're wondering why it's not surround. Well, it's not multichannel. Please fill in some details.
most of the new TV's use a SCAT plug to allow connection of a PC or laptop. I doubt that this TV has that sophistication. The ISB will not do it and neither will S VIDEO.
As for the cable you could try a male to male plug to mnake a coaxial connection. These TV's were made to a price for walmart and you got what you paid for which was a cheap TV. There was no warranty offered by Walmart for these either
get a surround sound system and once you hook up your audio you can then use the surround sound remote..avi in... to control your volume.. and use your direct tv remote to change channels
Make sure your audio outputs are turned on.Also try a connection from the tv straight to the stereo to see if you have sound !! If so then the problem is somewhere in between!! Check the settings for audio on these devices as well !! Good Luck !!1 Swampratt200 AAAAAAAAAAAAAAEEEEEEEEEE!!!!
