The only way to fix this is (A) go to a junkyard and get a used steering column and then have the key and pass code reprogrammed (B) go to the dealer ship and see if reprogramming the pass key will allow this to work. sometimes if the battery goes dead the pass key will not reconize the correct key for this car
SOURCE: my check engine light does not flash when i turn key before start
bulb is probably blown... you have to remove the instrument cluster to change the bulb
?ā¬Ā¢
The ignition cylinder
?ā¬Ā¢
The body control module (BCM)
?ā¬Ā¢
The starter relay
?ā¬Ā¢
The powertrain control module (PCM)
