SOURCE: I have a Samsung J1043
I rewashed the clothes a couple of times and finally the door released.
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
SOURCE: getting error 5e WF7708 samsung front loader. Have
A 5E code means that the drain pump is iether clogged, with lint, impeller damage, drain hose clogged, or a loose connection on the pump connectors
Testimonial: "i was draining the water out only coming out in dribbles so i think you hit the nail on the head....ty ty will give it a go..."
SOURCE: Samsung J845 error SE or 5E
Just did the above directions on my washer also.And to make things easier you can pull out the whole drainagehoses by removing 3 little phillips head screws and a couple of hose clamps.Then pull all hoses off individually and clean out all hoses and assembly a lot easier.
