Irons Logo
Posted on Sep 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I love my iron, BUT I used to be able to clean it by the recommended method, but now it will not shoot out steam to clean the holes. It does not steam on clothes even though I prees the steam button. The water level doesn't change either. I have changed the water several times but nothing changes. I have had this iron for about five years. What can I do?? Thanks for whatever help you can suggest!! Jan Brier
Bob Korsu
Level 3:
Guru:
  • Master 1,051 Answers
  • Posted on Sep 28, 2010
Bob Korsu
Master
Level 3:
Guru:
Answers
1051
Questions
0
Helped
403310
Points
3047
Put in as much white vinegar as possible and then turn iron on. Let it stay on for about 30 minutes the try the steam button. Once the steam button begins to work empty the vingar an fill with distilled water to rinse. You'll need to rinse several times to get all of the vinegar out.
How do I clean the steaming holes on my Tefal acuaspeed iron. The holes are blocking up & a shot of steam does not clear them
use a quality iron cleaning product in the tank
use on scrap material until there is no gunk coming out of the holes
Sep 19, 2018 • Tefal Irons
tip
Cleaning a Steam Iron Soleplate
During the day to day use of a steam iron there can be normal buildup accumulate on the soleplate of the iron. Other things such as melted synthetic fibers, iron-on trims, and fusibles can also buildup on the sole plate of the iron. These can be removed with the use of a quality hot soleplate cleaner. Soleplate Cleaning Kits can be purchased from many service centers or can be found online by doing a search for “soleplate cleaning kit”.
If you have had the misfortune of getting melted plastic on the soleplate of your iron, you can remove that by taking a piece of Aluminum foil and sprinkling it with salt. Then take the hot iron and work it back and forth over the salt to break up the plastic and remove it from the bottom of the iron.
Avoid starches and be careful of synthetic materials. Also avoid zippers and buttons that can scratch the bottom of your iron.
Do not use the soleplate cleaners on your iron if it has a non-stick surface. With the non-stick surface you should not need the cleaning anyway. These surfaces can be damaged easily by anything abrasive. Do not use abrasive cleaners on any soleplate. Use the soleplate cleaning kit.
The holes in the bottom of our iron can be cleaned by using a pipe cleaner of a Q-tip.
Simply make sure the bottom is cool and then insert the pipe cleaner or Q-tip into the holes one by one and circle them around inside to clean out the hole.
If your iron has a “self clean” feature, do not over use it. It is recommended that you use it at least once per year, but not more then once per month.
Also look for my other tips on taking care of your steam iron.
on Jul 14, 2010 • Irons
1helpful
My iron is not releasing steam at all. The motor is going but nothing coming out. It has done this previously but only for a couple if minutes. Will not work at all and only just over a year old.
I suspect that the iron is clogged with mineral deposits. This happens when ordinary tap water is used - more so if your tap water is "hard". First and foremost, buy a gallon of DISTILLED water.
Cleaning it is very much like cleaning an auto drip coffee maker. Empty the iron into the sink. The first method is to pour white vinegar into the reservoir and set the iron to the hottest setting. Tip the iron flat to allow steam to escape. Press any buttons that allow blasts of steam, too. The vinegar will dissolve minerals on the inside of the iron and clogging the holes on the bottom of it. If all holes are cleared after the first time, flush DISTILLED water thru the iron. If not cleared, you can try this second method: Fill it with vinegar again and leave it sitting flat in the sink - unplugged - over night. In the morning, refill with vinegar as needed and try the first method once more. It should be clear at this point. Flush with DISTILLED water.
You can prevent this from happening again by using DISTILLED water only in the iron. There are NO minerals in DISTILLED water, which are left in the iron when water is boiled off inside it.
Jan 05, 2015 • Irons
Need manual for rowenta DW2090 iron
I have provided a link to a manual that seems to belong to your model. But unsure what features your model has. This is not available for some reason at the Rowenta USA website.
Refer page 7 of the manual available at this site
http://laundry.manualsonline.com/manuals/mfg/rowenta/1103898336__4605.html?p=1
Self Clean - prolongs the life of the iron
The Self clean function flushes dirt and scale particles
out of the steam chamber.
To operate:
• Fill the tank with untreated tap water up to the maximum
mark and heat the iron to max. temperature.
• Unplug from the mains.
• Hold iron over a sink horizontally, push the steam control
3 past the position and into the Self Clean position
and hold it there: steam will now begin to build up.
After a few seconds water and steam will emerge from
the soleplate, rinsing dirt and scale particles out of the
steam chamber.
After approx. 1 minute move the steam control slide to
the position.
• Insert mains plug and allow the iron to heat up again.
• Wait until the remaining water has evaporated.
• Unplug from the mains and allow iron to fully cool
down.
• When cool, the soleplate can be wiped with a damp
cloth.
We recommend using the Self Clean function approx.
Every 2 weeks. If the water is very hard, the iron should
be cleaned weekly.
Self Clean Valve
The self clean valve prevents the drip hole into the steam
chamber from furring or blocking up. To ensure the iron
continues to function properly, open and close the valve
by sliding the steam control to max then min a few times
after use.
2helpful
While ironing with steam, scale deposits came out through holes. how do I clean iron
You can try this out, fill the Iron with a considerable amount of water, Switch On your Iron, Increase the heat controller Knob to the maximum so that the water boils and Place it Upside Down (As if you want to Iron) but dont let it touch the Pressing Table. Then keep pressing the button that disperses the steam until the whole water inside it finishes, repeat this same process over and over until it comes out clean...
(Alternatively however, you can just pour hot water though the water-inlet hole, and after a while, shake the iron and turn the water out upside down and let it pass out of the water-inlet hole...but please be careful with this second method though...because of the hot water)...hope it helps.
1helpful
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Water shooting out bottom holes
This normally means that the iron is not heating up enough check that you have adjusted the temp so it is not as the water will either come out of the bottom when not hot enough to steam or when the jets get dirty and need cleaning.
Thanks J
1helpful
Steam doesnt work
A mineral buildup from your water may be blocking the holes in the soleplate of your iron. Before you do anything, read the instruction booklet for your appliance or call the manufacturer. The old remedy of using vinegar to unclog an iron is no longer recommended for many models. Some manufacturers suggest alternating tap and distilled water in the steam compartment to avoid a mineral buildup; others recommend using a specialized cleaning product (available at fabric and grocery stores) to clean the soleplate.
Top Rowenta Irons Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
