SOURCE: I have a swiss legend swiss quarts movement watch.
mcdevito75 here, Possibly the battery is weak, (Need New Battery) or the quartz mechanism is going bad, see the repair service directory here at fixya, bottom of page click on repair service directory then watches.
SOURCE: how do I replace the battery in my Swiss Legend ceramic watch
Swiss Legend recommends that your watch be serviced for battery by a local and reputable jeweler in your area. For further advice on batteries, they recommend you contact them.
Email them at [email protected] or call 1-866-746-7794.
Good luck
SOURCE: i have a swiss legend
Most bracelet adjustments require a special tool that is only found in a jewelry store, or your watch can be shortened by the manufacturer. Many watches have pins that push out if you look on the back of the band there should be arrows the pins push in that direction if you have something small enough to fit it the hole, be very careful to put the pin back in the same way. Occasionally some watch bands are not pins they are screws and it can be very difficult to tell the difference between the two. If the watch band has a screw it requires a very small screwdriver and you must be careful NOT to strip the screwhead! You can also shorten some watches by just moving the pin in the band buckle if you have a small tool you should be able to do this yourself, BUT wear glasses because pins will spring out, keep pointed away from your face. Hope this helps!
SOURCE: How do I set the
If the day will not change when you pull the crown out to the first position (try both directions) then pull the crown out to the second position. Advance the hands until yesterday shows in the day window. Now set the date by putting the crown in the first position and set it to yesterdays date. Now advance the hands (position 2 until the date and day change and then set the time. Done
