Question about Swiss Legend SL-LUCERNE-ML134AC Wristwatch
I have a swiss legend swiss quarts movement watch. It will not keep time i set it and the second hand at the bottom will go for a while then stop. i am not sure what is going on. The model number is Swiss Legend Men's 20067-BB-01-RA thanks
Michael C. De Vito
    Genius:
  • 1,970 Answers
Mcdevito75 here, Possibly the battery is weak, (Need New Battery) or the quartz mechanism is going bad, see the repair service directory here at fixya, bottom of page click on repair service directory then watches.
Posted on Jun 25, 2010
I have a Swiss Legend Karamica Diamond watch. It has suddenly stopped working. Have now had the battery replaced twice. It works perfectly for three or four days and then stops. Any ideas?
Hi Leigh.
The battery supplies voltage to a precise timing circuit to generate brief pulses of low voltage electricity to a magnetic coil which swings a weighted cam (wheel) to keep everything in motion.
This cam or some other mechanical part may have become dislodged or misaligned, causing drag.
In a nutshell, a watchmaker will need to inspect it for wear.
Could be a jewel-bearing has fallen out.
Does this help?
Regards,
Clive.
Oct 28, 2017 | Swiss Legend Watches
I have Swiss legend challenger and it's new. How do you get the second hand moving.
Sorry...
New or not SWISS use the second hand as an early indicator of the battery state.
My memory is that it starts by skipping seconds...
Then the second hand stops...
Then the watch...
ELSE
The movement is bad.
If it is INDEED NEW... Take it back & get
yourself a fresh one.
Carnac the Magnificent
Mar 25, 2017 | Swiss Legend Watches
How to set the time on my swiss legend watch?
You will need to have your model number handy. Once you locate the model number you may find your operators manual here:
Swiss Legend Manuals
Aug 17, 2014 | Watches
How do I set the day of the week dial on my Swiss Legend Chronograph?
If the day will not change when you pull the crown out to the first position (try both directions) then pull the crown out to the second position. Advance the hands until yesterday shows in the day window. Now set the date by putting the crown in the first position and set it to yesterdays date. Now advance the hands (position 2 until the date and day change and then set the time. Done
Oct 14, 2012 | Swiss Legend Commander Chronograph Blue...
I have a Swiss Legend Monte Carlo watch. All of a sudden, the watch's hour hand seems to be stuck at time 8:00 however the second hand still functions. Popping out and spinning the time-set will not...
It seems unlikely that there is any built in function that would cause the symptoms that you describe but it could be something simple like the hand being loose on its shaft.
Yor local jeweler should be able to fix that sort of thing.
Jul 19, 2010 | Cartier Santos W20056D6 Wrist Watch
The second hand jumps forward every 5 seconds but the watch still keeps time OK.
You need to replace battery.
Q/A from swiss army website.
Q. How do I know when the battery needs changing?
A. In select models, the battery end-of-life indicator signals that the battery should be replaced within two or three days. When the battery is low, the second hand stands still for 2-4 seconds, and then speeds up to the correct time. This indication will last for approximately one week, and then the timepiece hands stand still.
Jul 02, 2010 | Swiss Army Wenger Victorinox Swiss Army...
The second hand stops on the minute hand
If the hands are binding the movement needs to be removed from the case and the hands set right. i.e. parrallel and not binding.
Jul 18, 2009 | Swiss Army Wenger Swiss Army Officer's LS...
Swiss g10-211 movement doesnt keep time runs when it wants to
This movement wasn't meant to be repaired, so replacement is your only option. These pop up new on eBay from time to time for around $30 shipped. Make sure you get one with the date in the correct orientation/position (e.g. date at 3 o'clock or date at 4 o'clock). Best to enlist the services of a watchmaker if you haven't removed and replaced hands on a watch before (particularly a chronograph).
Feb 25, 2009 | Swiss Legend Chronograph Stainless Steel...
Second hand moves every 4 seconds
the battery need replacing this is what its supposed to do when batt low. if this helps please rate joe
Nov 20, 2008 | Watches
Swiss Army watch 70609 second hand pauses
Battery life indicater just warning to get that battery replaced so it wont stop at an inconveinient time
Jan 09, 2007 | Swiss Army Wenger Standard Issue 70609...
Swiss Legend SL-LUCERNE-ML134AC Wristwatch Logo
1,044 people viewed this question
Top Swiss Legend Watches Experts
Janelle Schoonover
Janelle Schoonover
Tom Chichester
Marvin
Marvin
Are you a Swiss Legend Watch Expert? Answer questions, earn points and help others
