I am writing about the question I had vis-a-vis how to get the CS-2030 to copy on both sides.
Rev. Johnson
I will attempt to help you with your problem. Keep in mind that I happend upon this post and I have absoultely no idea what has transpired before this contact with you today. Hopefully I can resolve your situation.
The CS-2030 does NOT come with a duplex unit as standard equipment. If your unit does not have an AD-61 duplex unit attached you will not be able to perform this function automatically. You can, however, use the bypass tray to reinsert the copy to ad a second side image. If you can tell me for certain that your unit is equipped with a duplex unit I will be glad to research your issue futher.
Waste toner reservoir overflow
problem (when the total number of
copies is 100 thousand sheets or
more)
• After E31 is displayed, 1,000 sheets
are copied. Or waste toner exceeds
5 g.
Defective waste
toner sensor or
engine PWB.
Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine PWB.
No, I have not solved the problem. Your company has take the $9.99 out of my bank account, but has not contacted me with the information I have requested. I am still waiting a response from you. My initial question was "how do I get the CS-2030 copier to copy both sides at one time."
Rev. Johnson
