Posted on May 21, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Amplifier has blown supplied speakers and I need to find someone to repair the amp and repair/supply replacement speakers
Anonymous
Level 3:
  • Master 4,234 Answers
  • Posted on May 21, 2008
Anonymous
Master
Level 3:
Answers
4234
Questions
Helped
1564679
Points
12312
It would help to know where you are located and what the receiveer and speakers are.
Thanks,
Dan
1helpful
Roksan Ka1 MkIII integrated Amplifier preamp works but not power amp. Two fuses on circuit board show no continuity, but are soldered in. What would have caused this and how to repair
Very likely the power amp output transistors are shorted and need to be replaced. The fuses provide power to these transistors. To verify this diagnosis, (with the speakers disconnected and the unit unplugged, of course!), check for continuity between the fuse terminal and the speaker output at the amplifier board (before any protection relay). If you have continuity (< 1 ohm resistance), the transistor is bad. Most power amplifiers have one transistor to the DC+ power supply and another to the DC- power supply. Both are connected to one speaker terminal, and the other speaker terminal goes to power supply ground. If one transistor shorts out, it overloads the other transistor and fries it as well. Even if it tests good, it's probably been damaged and is likely to short and ruin the new transistor, so replace both at the same time. The foregoing holds true if the output transistors are inside a power amp module.
Note: check your speaker wiring (both ends) after repairing the amplifier. A stray strand at the speaker connector shorting to the other terminal or ground can destroy the output transistors. I once had a customer who had too much bare wire exposed on the ends of his speaker wire. It was fine until his wife turned the speaker upside down during cleaning and twisted the bare wires together (and forgot to right the speaker afterwards). He bought fuses and transistors ...
1helpful
Marantz PM7200 Stereo Amplifier: Can a production fault with an amplifier cause it to keep blowing the speaker on one side, while the other side's speaker is fine?
It could be the amplifier but most likely it’s going to be either the connections or a power supply issue. Do you have anything plugged into the same outlet? What type of power strip are you using. The amp will usually go into a protect mode as to not damage anything before it would create the environment to cause a blown speaker. I know that with your model, along with multiple others, have had issues with the power board needing replacement.
Where is the fuse in a xr1220 mixer.
which fuse?? main fuse? output fuses?
if the main fuse has blown & the device simply won't power up, replacing it will merely result in another blown fuse - you need to take it to someone who can repair the units' power supply
output fuses blow when speaker wires are shorted, or speakers fail short - they're on the main circuit board, but seeing you're asking, i'd suggest you don't open the unit, but take it to someone who knows what they're doing
1helpful
2answers
Red light on on amp
take speaker wires off amp if the lit is green then speaker are hooked up wrong or blown.
2helpful
2answers
Speakers no power
No Power means no supply. Step by step troubleshooting is recommended. Start with the main source power,then the cable wires,then to the primary section of the circuit board.Some components may be busted already.
The Amp doesn't come one. it shutdown after it was used.
There are three entries for this same device. If you have overposted these, the symptoms combining the three would indicate that one of the power amps has probably shorted and overloading the power supply till a fuse has blown DO NOT replace the fuse till unit is repaired.
This is not a do it yourself repair unless you are competent in electronic repair.
High power amps are easily damaged by intermittent speaker lead connections and shorts as well as overdriving them into too low a speaker impedance.
I ran the amp in .5 ohms and it is only 1 ohm stable now the protect light comes on what could it b.
Blown protection circuit at best. Blown power supply and IC's at worst. Send it to a service center for an estimate, educated guess without having it on a bench in front of me $150-200 repair. To test for the possibility that it's not the amp, disconnect speakers and turn power on. If it stays clean, no"protection", check your subs for a shorted voice coil. Hope this helps.
My amp is melting its 30amp fuse
Amp had a problem. Blown amplifier or power supply. It will need to be removed and repaired by a qualified tech. There's no way around it.
1helpful
Amp turns on just fine but no sound comes out
Amp Failure:
There are many different ways that an amp can fail but the two most common failures are shorted output transistors and blown power supply transistors (< those are not blown). There are several types of protection circuits in amplifiers. The most common are over-current and thermal. The over-current protection is supposed to protect the output transistors. Sometimes it doesn't work well enough to prevent the failure of the output transistors but it will work well enough to shut the supply down before the power supply FETs are destroyed. If the amp remains in protect mode, goes into protect mode or blows the fuse as soon as the remote voltage is applied, shorted output transistors are almost certainly the cause. If the fuse protecting the amp is too large, if the protection circuit doesn't respond quickly enough or if the power supply is poorly designed, the power supply transistors may fail. If you see a lot of black soot on the power supply transistors (near the power transformer), the power supply transistors have failed. Soot on the board doesn't necessarily mean the transistors have failed. Sometimes, technicians don't clean up the mess from a previous failure. Transistor Failure/Checking Transistors:
In general, when a transistor fails, it will either short (common for output AND power supply transistors) or open (common for power supply transistors). Transistors act like valves. They control the current flowing through a circuit. A shorted transistor acts like a valve that's stuck open (passing too much current). In the case of an output transistor, the shorted transistors tries to deliver the full rail voltage to the speaker output terminal. If you've ever seen a damaged amp that pushed or pulled the speaker cone to its limits when the amp powered up (common on some Rockford amplifiers), that was almost certainly due to a shorted output transistor. When checking transistors, you most commonly look for shorted connections inside the transistor. You do this by using a multimeter to look for low resistance connections between the transistor's terminals.
Seems as you have blown an output. Seek repairs.
1helpful
Amplifiers esc200
Hi! The fact that the LCD has power implies that the fault is in the Power Amp-Speaker stage.
Check 1: Check that your speakers are connected to the amplifier output properly.
check 2: If connection is proper check for power on/power off blips. If blips are heard the Power amp /speaker stage is ok .
check 3: If power on/off blip is heard then you have to check the source stage i.e CD/radio etc
Check 4: if blip is not heard. Disconnect the speaker and try with another. eliminate the case of a blown speaker by testing speaker on another system.
check 5: if speaker and source are ok. Treoubleshoot the amplifier Power supply stage with the followinghttp://www.howtodothings.com/electronics/how-to-fix-the-fuse-on-your-guitar-amplifier
check 5: if the power supply to power amp stage is ok troubleshoot the power amp stage with this guidehttp://www.howtodothings.com/electronics/how-to-fix-your-guitar-amplifier
If you still face problems feel free to contact me
 Grubhead
Grubhead
SmartAviator
SmartAviator
