The tube that the coffee comes out would seem to be blocked. My suggestion is to take some air pressure from an air compressor and blow it into the nozzle and see if you can blow anything out.
Give this a try and let me know if it helps, if not let me know.
Please let me know if you have any questions on how to do this. The only other spot I would look is to the pump. When it does give you some coffee, is it coming out normally or less than usually and how does it come out compared to when you first got it? let me know as this can help narrow down the problem
The air won't damage anything as long as you know what you are doing. As long as you don't seal the compressor nozzle into the tube, no damage will occur
you could also try running a steel wire with a brush at the end into the tub to clean it
Were you able to fix this, if so then please give me some feedback by rating my solution. If you need any more help, I would be glad to assist you, just ask.
thanks and Have a Great Day!
The pump appears not to have enough pressure , you should call Krups to get a replacement.
You have a faulty pump, hard reset is unlikely to help in this case.
Ask other experts were to find a repair centre in your area.
Good luck
Hard reset is unplugging power cable for some time, to solve electronic problems. In your case start finding Krup phone number, or a repair technician in your area, as you do not seem a DIY expert on this kind of machine.
Regards
Last thing blowing with the compressor right inside the water pipe can cause further damage.
Try THIS article..It should help.
Try THIS as well.
please send an email to [email protected] and request the refund.
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours). Of course doing a hard reset erases all glitches.
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
As posted, initially, then perhaps you would like to check and consider a "Recall Alert" on some models of Krups Epresso Machine. Pls reference this page.
I did try your solution several times, even left it unplugged for over 2 weeks, to no avail
I did try your solution, had the machine unplugged for days at a time, to no avail.
Many thanks, my machine is not listed as a recall, I have spoken witn Krup about it, they gave me the solution of using this site.
The advise I got from you, unfortuntely is no help at all. Kindly help me or get someone else's help for me.
Thanks
Tried them both, they do not apply to my machine.
Need another expert opinion, none of your solutions have worked.
Thanks
What do you mean by "a hard reset"?
Your solutions do not apply to my machine, the ones that apply, did not work, kindly get me other solutions or a different expert.
Thanks
None of your solutions have worked.
Kindly let me have the name, phone number and address of a repair center for my machine in Manhattan, New York.
Thanks
Yes, I did use the tablets.
After pressing hot water, the next message is "machine ready"
Thanks, but none of your recommendations worked, we are doing away with the machine and buying a more reliable kind.
Kindly take the necessary steps to refund the fee you charged me for the advice as per your written waranty
Sorry, your advice was of no help, we are throwing away the machine and purchasing a more reliable kind.
As per your waranty, the fee I was charged is to be refunded to me.
Thanks
