Leviton WHT SLIDE DIMMER  Logo
Posted on Sep 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have a leviton slide dimmer controlling 4 pot lights with gu10 bulbs. There is also 6 receptacles on this 15 amp circuit. I had a regular 2 pole switch on there, with no problems. When I converted to dimmer, the dimmer popped. The lights still work, but the dimmer does not. I am assuming the transformer popped. The gu10's are only 50 watts and the dimmer is 600 watts.
Anonymous
Level 3:
  • Master 843 Answers
  • Posted on Sep 17, 2010
Anonymous
Master
Level 3:
Answers
843
Questions
0
Helped
394518
Points
2420
You said they are 50 watt GU10's, so I would assume they are 120V halogens, and you must simply have gotten a bad dimmer. But if these GU10's are 50 watt equivalent (LED's or CFL's) then the bulbs will have their own transformers built into them, and would be incompatible with a dimmer switch. It also might be the case that you have low voltage halogens which would use a transformer, shared or individual, and these would also be incompatible with a dimmer. (I don't know offhand if GU10's are available with low voltage halogens.)
2answers
Installed Leviton Decora Slide Dimmer switch 6672 and moving the slide turns on the lights but I have no dimming action ?? Using dimmable LED light bulbs I replaced a regular Leviton switch.
https://www.leviton.com/en/products/6672-1lw
Specs say Dimmable LED lights are fine, so that means your lights are the ones at fault. Although marked dimmable, they are aren't. Swap the bulbs out for another make. Also if you read the FAQ on the lower section of the page, there are secret switches hidden behind the slider. Also interesting to me is that on the top metal fixing plate it shows
LIGHTED OPTION
ON - OFF
Does a leviton slide dimmer switch use regular bulb's
what do you know as "regular " bulbs
are they low energy or incandescent
1helpful
What model Leviton GFCL should I use? My wire is a 600 volt 12/2 with ground. Said wire feeds other GFCL outlets.
Any off-the-shelf GFCI sold today with work on 12-2 wire:
By code, 12-2 wire should be connected to 20 amp circuit breaker, but typically most switches and outlets wired to that circuit are rated 15 amp. Amp rating is printed on electrical devices.
Leviton 15 amp 7599-W:
http://www.amazon.com/Leviton-7599-W-Receptacle-Feed-Through-SmartlockPro/dp/B000VYO9MU/ref=pd_cp_hi_3
Leviton 20 amp 7899-W
http://www.amazon.com/Leviton-7899-W-SmartlockPro-Indicator-Wallplate/dp/B000N663PM/ref=pd_cp_hi_0
Wiring:
http://waterheatertimer.org/How-to-wire-GFCI.html
Needed to turn another circuit off to change a bathroom light fixture. In the process of finding the correct breaker for this project, another circuit was tripped for my dining room where there is a...
Just tripping the breaker should no affect your dimmer unless maybe malfunctioning or wired incorrectly or loose connection. It is hard to wire incorrectly, for there should only be two wires attached to the dimmer? Replace dimmer and make sure wiring is correct if not sure about wiring yourself contact local electrician for your safety. There are very good instructions inside the switch packages, make sure to buy a quality switch, Leviton is a good name I would lean towards faulty switch or loose connection but I'm not there. Good Luck Karen....
Apr 20, 2011 • Home
2helpful
How many 15 amp receptacle oulets on a 20 amp CAFIC branch circuit?
The National Electric Code (NEC) does not directly state the number of outlets per general purpose circuit for a residence. They only state that "x" amount of sq. ft. must have "y" amount of circuits and that they be evenly distributed. The number of outlets is then limited by physical outlet spacing rules.
However, a rule of thumb is the points system. A 20 amp circuit is 20 points. A regular duplex receptacle is 2 points and a light is 1 point. You can have any combination of receptacles and lights that add up to 20 points. For example, 10 duplex receptacles x 2 points = 20 points. Or, (8 duplex receptacles x 2 points = 16) + (4 lights x 1 point) = 20 total.
The concept is the same for a 15 amp circuit except the total points will then be 15.
So, the answer is about 10 receptacle outlets per 20 amp circuit. In a pinch, you can stretch that to 12 or so and still be OK.
I have an overhead panel of eight 4' flourescent lights which I believe are each 40 watts. The dimmer switch that controls them all as a unit has failed. Any suggestions about where to get a replacement...
Google-search: florescent slide dimmer
You have 320 Watts, 120 volts, and the circuit uses 2.6 amps.
Volts x Amps = Watts.
1) The florescent slide dimmers seem to cost $100-120
2) If you search for florescent dimmer, the cost is lower than the slide dimmer.
Leviton sells for $50
http://www.google.com/products/catalog
2helpful
2answers
1helpful
Dimmer turns on/off 3 spotlights but they wont dim
Questions to answer so I can answer/resolve your problem:
1) Is this a rotary style dimmer?
2) Is it a toggle or slider type?
3) Is this on a 3-way circuit (that has 2 or more switches that can turn the lights on or off)
4) Is this on a single switch circuit?
5) Is this a brand new dimmer switch?
6) Is this an old dimmer switch?
7) Are the light bulbs in the spots regular incandesant or halogen bulbs?
8) Are the light bulbs in the spots CFL (compact flouresent lamps)?
With this information, I can tell you what the problem is:
If you answer "YES" to #1, and or #6 then the dimmer is faulty and should be replaced.
If you answer "YES" to #8, then you have the wrong dimmer for the bulb type, as CFL's require a specific dimmer type in order to dim them.
Please provide some more info and maybe we can help you figure out what's wrong.
Hope you find this Very Helpful and best regards!
Top Leviton Electrical Supplies Experts
john h
Sean Wright
Sean Wright
CJ Rock
CJ Rock
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
