SOURCE: no voice, no map display beyond 30 mile range, slow to compute
Did you try updating your unit's firmware?
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
SOURCE: 60CSX altimeter problem
I fixed this problem in my 76cs by doing a factory reset.
It kept all my maps, but dumped all waypoints and tracks.
After that, the altimieter problem was fixed.
Your reset will vary, and can easily be found on google. Mine was
http://gpsinformation.us/gps60c/g76Creview.html
Complete Reset:
Press
"Enter, Page, and Power on keys" to get to the message that says, "Do
you really want to erase all user data". Before you say "YES", I would
strongly recommend you download your waypoints, tracks, and routes to a
computer, and write down your settings as they will all be erased or
reset. Of course your software version will remain the same, and
any downloaded maps will still be there.
And
then: From the Trip Computer Page, while there push the scroll key up,
right, down, & then left to get to a diagnostic screen used by
Garmin Techs. I would not recommend playing with this screen too much,
less you want to ship your unit back to Garmin for repair!
SOURCE: need to pick perfect amp
I suggest to use separate amps to your sub, get a 2 channel amp for your sub and 4 channel amps for your speakers.
Here are my Top 5
SOURCE: i have 3 hifonics zeus
Hello king3132,
Three 4 ohm subs can be wired parallel for a 1.34 ohm final load or series for a 12 ohm load. If you have the channels of the amp bridged, I hope that the subs are connected in series because the Sony XM-2200GTX is NOT rated for or stable at 1.34 ohms. It's only stable down to 4 ohms.
You definitely will not get the maximum potential of the subs from that amp. They can handle 400 watts RMS each (total 1,200 watts) and the amp is only capable of 500 watts RMS into 4 ohms (less at higher impedance), so each sub could only be getting a maximum of 166.6 watts RMS.
Hope this helps.
Php = PkW / 0.746 (2)
or
Php = (?m U I / 1000) / 0.746
= ?m U I / 746 (2b)
where
Php = horsepower (hp)
