Check the wiring to the starter sounds like your starting wiring is not making good contact if not test with a test light and check the fuse hope this helps
Hi, this tells me the solinoid is not working, i do'nt know if the SOLINOID is on the starter motor or on the side of the wing. if you turn the ignition key do you hear a click. if click is heard. this means the solinoid circuit for the starter is working, but the HEAVY SWITCH PART of the SOLINOID is not connecting the BATTERY to SOLINOID to the STARTER MOTOR. there is a ELETROMANECTIC coil and a very heavy (switch) in the SOLINOID. gerry
