Casio FX-115ES Scientific Calculator Logo
Posted on Sep 06, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I type in the equation .933 ^ 1.5 That
How do I type in the equation .933 ^ 1.5 That is ,933 to the 1.5 power squared and cubed okay, but 1.5? please help.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Casio Master 102,366 Answers
  • Posted on Sep 07, 2010
Casio Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444268
Points
622693
. 9 3 3 x^ 1 . 5
x^ is marked on the keyboard as an x with a superscript rectangle on the key above the sin key. This function lets you raise a value to any number, including 2 and 3.
How to find values of x in higher order equations(above cube) on casio 570 ES?
In equation mode, you have system of linear equations (3 unknown) you have polynomial (quadratic and cubic), and solver. Use the solver foe any type of equation (nonlinear, polynomial of order higher than 4, trigonometric, exponential, logs).
How do i calculate my rational equations using my casio fx-115es for example x/8=8/x
You do not need a calculator for this proportion.
For a proportion a/b=c/d, the product of the extrems (a*d) is equal to the product of the means (b*c).
In your case x*x=8*8 or x^2=64.
The two solutions are x=+square root (64) or x=-square root(64).
For a less trivial equation, you can use the solve feature of the FX-119ES. To do so, use the ALPHA keyboard to enter your equation; once the equation is typed in, do not press the main equal sign, but the Solve key (the key is located near the top left corner of the keyboard). You will be prompted to solve for X?.
Is time three dimentional or four dimentional?
Because of Einstein, we often call time the fourth dimension. Special relativity shows that time behaves surprisingly like the three spatial dimensions. The Lorenz equations show this. Length contracts as speed increases. Time expands as speed increases.
Scientists have been graphing time, as if it were a length, for hundreds of years. To the left is a typical graph, showing two things in motion at the same speed, one to the left and one to the right. Time never behaves exactly like a spatial dimension. You cannot go backward in time. And you normally cannot go forward at different rates. But, there are surprising parallels. For some purposes, it is handy to call time a fourth dimension. For other purposes, it is not.
Pretend, for a moment, that there are more than three spatial dimensions. What is a four or five-dimensional cube like? It is hard to visualize. But, we can make a few deductions about such an object. What if a 5-dimensional cube is 2 centimeters on a side, what is its 5-dimensional volume? Well, we can easily generalize from the first three dimensions. A 2x2 square is 4 (2x2) square centimeters in area. A 2x2x2 cube is 8 (2x2x2) cubic centimeters in volume. A 2x2x2x2x2 5-dimensional cube is 32 centimeters-to-the-5th-power in 5-dimensional volume. None of that can be visualized. But, it makes sense. What is the distance between two points in 5-space? You can easily deduce a 5-dimensional Pythagorean Theorem.
A science fiction story says that time is the fourth dimension, and space is the fifth. Space is the first three dimensions
2helpful
What are the 7 classifications of special product (algebra)
1. Square of a sum
2. Square of a difference
3. Difference of square (also called product of sum and difference)
4. Cube of a sum
5. Cube of a difference
6. Difference of cube
7. Sum of cube
For more information about each type click this link.
2helpful
How do i do a number 'to the power of 1/2 or 2/3? cheers Brad
Power 1/2 is the same as square root: You can use the square root key to the left of the square key.
Similarly power 1/3 is the cube root. You use the [SHIFT][Square root] key sequence.
Power 2/3 is the square of the cube root, or the cube root of the square.
More generally, you can use the universal power key, marked with X with a raised white rectangle. It is between X square and log.
Ex: Calculate 15^(2/3)
15 [X with raised rectangle] 2 [/] 3 [)] [=]; the result is 6.082
The last parenthesis closes the left parenthesis introduced by the calculator.
Alternatively you can use the cube root and the x-root selections available under the MATH menu.(selections 4 and 5)
How to type suffixes and squares, cubes, k bar?
Hi, there may be other "Questions" along the way that may need answering, one of the best information centers, is the (?HELP!), it is located on the Microsoft (WORD) Menu Bar; just look for the ("circled?"). ou can enter a question in the search (box), or go to: the "Table of contents" for a listing of most ask question etc. "I hope this helps' Ya"s
376c backlight wont get brighter. I adjust the intensity anbd nothing happens
find two consecutive cube numbers or integers whose difference is a square number. i know it is 8 and 7 but hav to get the equation
1helpful
3answers
How do I solve radical expression and equations using the TI89?
1. square of 12
2. cube root of 48 a raise to 5 y raise to 6
3. square root of 128 y raise to 5
4. 6th root of 9 y raise to 2
5. cube root of 24 y raise to 5
6. 10th root of 32 x raise to 5
7. 15th root of 64 x raise to 9
8. 4th root of 10000
9. cube root of 192 p raise to 5
10. cube root of 256 y raise to 12
9helpful
3answers
Trying to find the hypotenuse of a trangle
A squared + B squared = C squared
15 squared + 15 squared = C Squared
225 + 225 = c squared
450 = c squared
the square root of 450 is 21.21320433
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
