My craftsman pressure washer wont run unless it is choked all the way. can you tell me how to fix this
I have a Karcher pressure washer w/ a 5hp Honda engine. It only will run while the choke is pulled out and only runs at about half the rpm's. When the choke is pushed in.. it coughs, sputters and shuts off. Can you tell me how to fix this....
Clean carb sounds like its gummed up
My ryobi pressure water only runs with coke on
Try removing the air filter to see if it solves the problem.
If that works replace or clean the air filter.
